We would have to know the make and model to give a proper diagnosis, but on the surface it sounds like something that happens with Delta and Moen faucets when either the stop in the handle or the one on the stem breaks off. I do not believe either of these companies ever made a three handle faucet, however, so it is probably a different brand but the same problem. The other possibility, but it would be rare to happen to both hot and cold at the same time, would be if you have screw type stems and they were stripped so that when you exerted extra pressure on them after they were closed they "popped" back out and turned on again.
