Results 1 to 6 of 6
Thread: Assembled Height not height than 26 1/2" inches
    DIY Junior Member
    Dec 2013
    So. California
    Default Assembled Height not height than 26 1/2" inches
    We have a toilet that we need to replace. Due to the counter placed over the toilet we're limited on space. The toilet that came with the house was made by Mansfield, and is approximately 26 1/2 inches high from the base to the top of the bowl with lid. My wife and I have been all of the internet and at our local Home Depot and have not found anything close, except one that was around $1,000???. We're looking for either some specific options or perhaps a site that we can filter by assembled height and not what we seem to find which is bowl height.
    Apr 2012
    New York, NY
    Quote Originally Posted by pecck View Post
    Most standard-height toilets are going to be between say 27.5 and 30 inches high.
    The Toto Supreme II is a great toilet and only stands 25-9/16". Model Number MS634114CEFG
    Here's the spec sheet: http://www.totousa.com/Portals/0/Pro...34114CEF_G.pdf
    Street price about $499-ish in white.
    DIY Junior Member
    Dec 2013
    So. California
    Quote Originally Posted by wjcandee View Post
    Thank you very much for the quick response. I should have mentioned that we're looking for something that is $300 or less ... if possible.
    Good luck! If you do find one at that price, invest in a good plunger to go with it.
    You must have a very "thick" countertop, because most are at 31" to the top and 1 1/2 to 2 inches thick which should give you a 29" high toilet space. In the old days almost all toilets fit under the counter, but now, because of the low flush volume, the tanks are higher to create more pressure.
    Sep 2013
    I think pecck wants to leave a little room for maintenance. Too bad the counter is not on some kind of lift-up mount.
  1. help with options for comfort height bowl toilet, shelf on wall limits tank height
    By bridgeman3669 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-07-2012, 06:12 PM
  2. Comfort height not so comfortable for petite to average height women
    By avghgt in forum Toilet Forum discussions
    Last Post: 01-01-2011, 04:05 PM
  3. Bright White Rear Exit "Comfort Height" Toilet
    By Ikat in forum Toilet Forum discussions
    Last Post: 09-01-2009, 04:00 PM
  4. Highest height on comfort height toilet
    By BOB J in forum Toilet Forum discussions
    Last Post: 03-05-2009, 12:43 PM
  5. Standard height vs. comfort height
    By Cygarbuff in forum Toilet Forum discussions
    Last Post: 11-12-2004, 08:35 AM
