emcdonel
Hello, everyone!
I'm Erik and I'm new here. I admit, I am here for your knowledge. I was hoping you could answer a question for me. Note the attached, please.
My problem started when, as a first-time homeowner, I didn't realize that to unscrew the bottom of our whole-house filter, I had to release the pressure via a button on top. I ended up torqueing the container too hard with the removal tool and snapped the incoming (PVC) water line.
To repair, I had to drain two (?) pressure tanks, a newer blue one on the floor and an old white one on a shelf. When I drained the white tank, an *enormous* amount of rust came out in the water, to the point it was almost like draining mud.
You'll see I was sloppy with the primer, sorry. I was in a hurry. I also realize I put the valve too low and now need to move it up six inches, but that's beside the point, and I'll fix that.
The point is that when I turned the pump back on and everything refilled, I was getting rusty water at all the faucets. It would run clear at first and then, in about five seconds, run very rusty for about twenty seconds, and then run almost clear. It's been doing this for a week now, with absolutely no improvement. It is both hot and cold water, so it's not the water heater. I also checked the filter, which comes into play before the pressure tanks, and they are very clean.
Incidentally, the hardware is for a spring, not a well.
Here are my questions, oh wise ones:
1) Why are there two pressure tanks? Is that normal or not? I've noticed the previous homeowners did all kinds of bizarre things, so maybe this is one of them? Or it's normal?
2) Can I just remove the older white pressure tank that I believe is causing the problem, just leaving the blue one on the floor?
3) If I do this, is it a problem that the pressure tank sits on the floor, a good seven feet below where the water comes in?
4) Or do I need two pressure tanks?
