Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Thread: Water Pipe Hammering
    DIY Junior Member wee-haggis's Avatar
    May 2010
    Ontario
    Default Water Pipe Hammering
    I recently moved into a 50 year old house and started to noticed water hammering (at least I think that what it is).
    No matter which faucet I turn on or off it...clunks each time (bathroom ,shower,washer,kitchen etc).
    It appears to be coming from a semi-inaccessible location in the basement ,above the gas water tank.
    Although I have'nt measured the water pressure coming in, it appears to be quite high (but not overly so).
    If I have the cold water running then turn the hot water tap of and on....there is no clunking, if I turn the hot water off and on ,on its own...it clunks.
    The hammering is coming from the general area above the water tank which I can partially view. As far as I can see the pipes pass through tight holes in joists but are other wise un-clipped.
    Is this something a water hammer arrestor could solve, if so where would be the best place to locate it and would it be needed on both hot and cold ?
    DIY Senior Member kcodyjr's Avatar
    Nov 2013
    Chelmsford, MA
    Hammering *everywhere* is a little bit suspect, IMO. It's only commonplace where fast-closing solenoid valves are involved, or when you turn a valve quickly from max to zero.
    I think your first move should be to measure your static water pressure. You might need a pressure reducing valve (PRV, or regulator).
    If that's not it, then you'll need hammer arrestors. To work properly, they need to be installed right next to each fixture. To explain that: water hammer happens because water has momentum, like everything else in the universe. When a valve closes, there's nowhere for that moving water to go except to slam into the valve. This creates a pressure wave that travels backward through the pipe at the speed of sound, stressing every part of the system. This energy usually spent making the pipes jump around and whack into the wall, hence the noise, but sometimes the result is a blown joint. A hammer arrestor is basically a shock absorber that prevents the pressure wave from forming.
    Feb 2011
    NW Ontario, Canada
    Quote Originally Posted by wee-haggis View Post
    My take is that what you are hearing is heat traps on the HWT, not water hammer.
    May 2010
    Ontario
    Quote Originally Posted by kcodyjr View Post
    Thanks.
    Appreciate explanation
    May 2010
    Ontario
    If indeeds its heat traps,how is this resolved ?
    Remove the pipe nipples with heat traps.
    I just did that this morning for a customer. No hammer on that one, but flow was restricting, and noise volumne had gone up.
    Pulled the nipples with ball checks and that solved it.
    May 2010
    Ontario
    Amateur here,so assistance needed.
    I've attached a photo showing my tank. Cold water on right (3/4" or 5/8") and hot on the left (1/2").
    Jan 2008
    I would be looking for a section of pipe that is not properly supported and is banging on a framing member or another pipe.
    Nov 2013
    Chelmsford, MA
    cacher_chick's suggestion is as excellent as her tagline, but bear in mind it makes the assumption that the problem is indeed hammering resulting in pipe movement resulting in an audible banging noise.
    There might still be something to the other theory of a bad heat trap, and independently of that, a static pressure test is still a good idea.
    It isn't clear, does the effect occur when messing with the cold water alone? How about when the toilet shuts off?
    I disconnect the pipes from the water heaters and extract the plastic, or metal ball, flow check devices.
    Feb 2011
    NW Ontario, Canada
    Looks like the same brand/model as my rental tank. It doesn't look like your cold side has a union, so it would require cutting and sweating.
    I just put up with the clunking noise. Every now and then the traps stick from sediment and affect the flow. At one point I queued up a service call with the rental agency to remove the traps but it cleared itself up so the wife cancelled the service call.
    May 2010
    Ontario
    I took some photos in inaccessible areas and what you see is the hot water pipe (in the foreground) going from right to left (then down to bathroom sink),the pipe beyond that is the cold water line teeing off of the main incoming water supply (which then carries on to the water tank). It appears that the hot pipe is sitting on top of the cold (even looks like its making some sort of rubbing mark). Could this be tjhe problem ?
    Feb 2011
    NW Ontario, Canada
    Use a stethoscope to narrow down where the sound is coming from.
    May 2010
    Ontario
    I have already determinded that the sound is coming from the area shown in the previous image
    Nov 2013
    Chelmsford, MA
    Insufficient resolution for a conclusion. If you want to be sure of what you're going after, you need to pinpoint the sound.
  1. What Causes Repetitive Water Hammering?
    By jimolson in forum Water Heater Forum, Tanks
    Last Post: 05-09-2011, 10:33 AM
  2. Pipe Hammering - How Should I Fix?
    By proteus in forum Shower & bathtub Forum & Blog
    Last Post: 10-30-2008, 06:59 AM
  3. Water Hammering
    By fastmat23 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-21-2008, 11:29 AM
  4. Water hammering, no, jack hammering
    By Grayfeathers in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-12-2008, 06:46 PM
  5. hammering water
    By rburt5 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-03-2008, 04:27 AM
