Thread: Installing toilet drain through floor joists
    DIY Junior Member Doomus's Avatar
    Dec 2013
    Ontario
    Default Installing toilet drain through floor joists
    I am in the process of renovating a bathroom and am looking to relocate the toilet drain and install a new toto maris toilet. The new location means I would need to put the 3" drain line through two 2x8 floor joists (which I know is not possible). What is the best way to move the drain?
    Without a good picture of where the drains are now and the joist runs, and where you want them to be, there's really no way to tell you how to move them and make it all work. Sometimes, the easiest way isn't all that aesthetic, since it may work out best to run the new pipe underneath them, but that may not be practical.
    You can't run through the 2x8 joists.
    You can run between them or under them. Sometimes that means finding a good spot below, where the pipe can later be concealed. Near a wall is a good location.
    Othertimes, you can move a vertical in a wall, and come up in a spot where it will run between the joists.
    You can barely run across with 2x10, no way with 2x8
    You may have to "header" the joists to create a "slot" for the pipe.
  1. Offset Toilet Flange or Header Joists and Relocate Toilet Drain?
    By sprusgoose in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-30-2013, 11:30 AM
  2. Shower drain between, then under floor joists...
    By pghsebring in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-22-2011, 10:55 AM
  3. Moving toilet drain across joists
    By TRSHAWSR in forum Toilet Forum discussions
    Last Post: 10-24-2007, 09:31 PM
  4. Wall hung toilet or drill floor joists
    By apanda2 in forum Toilet Forum discussions
    Last Post: 01-16-2007, 07:16 PM
  5. Moving toilet waste line through floor joists
    By surfer in forum Remodel Forum & Blog
    Last Post: 04-26-2006, 10:16 AM
