Thread: Kenmore Fridge Ice Maker Not Freezing
    DIY Junior Member wneikrie's Avatar
    Dec 2013
    Denver, CO
    Default Kenmore Fridge Ice Maker Not Freezing
    Hi! I have a Kenmore 795.78409.801 fridge and the ice maker has stopped freezing ice. Both the fridge and the freezer are maintaining proper temps, but the cold plate in the ice maker compartment is warm to the touch. I have no water flow issues... I turned off the ice maker all night and am now waiting to see if turning it back on has inspired it to start up again.
    Thanx!
    Is it possibly stuck on the defrost/release ice mode? Do you have the manual that came with it? That often has a troubleshooting section in it. On some, once it has frozen the ice, it then warms the edge so it releases cleanly, then turns back off so it can make more ice.
    I put ice makers in the same category as disposers. Just not a repairable item. Look by the serial number & see if you can see something that reads like: Icemaker kit: IM501. Google it & you should be able to find one for around $50. I've used both the oem replacement ($200) & the no name brands & don't see a difference in longevity. Takes about 10 minutes to install.
    The gear is probably stripped which stopped the cycle.
  1. Please help with water line connection to fridge!!
    By krazynuttz23 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-08-2009, 10:58 AM
  2. Does Molo live in a fridge?
    By Ian Gills in forum Ian's Corner
    Last Post: 02-21-2009, 05:09 AM
  3. Fridge Ice Maker Water Line Burst - HELP!
    By Franner11 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-25-2008, 09:58 PM
  4. Fridge plumbing
    By Bassman in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-25-2006, 01:02 PM
  5. Plumbing a Fridge
    By kenzo42 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-07-2006, 06:41 PM
