Results 1 to 4 of 4
Thread: Ok to run shower piping out of tub port on valve?
    DIY Junior Member copper piper's Avatar
    Dec 2013
    Maryland
    Default Ok to run shower piping out of tub port on valve?
    Hello-
    I have 2 seperate shower units in my stall. Plumber piped one valve correctly, but piped one with shower pipe exiting out of the tub port on valve. I seem to have a bit of water hammer or spool play in cartridge now.
    Is it OK to pipe to shower from tub port (lower) on valve or should it be redone to go out of shower port (top) on valve?
    Thanks in advance.
    bb
    Some plumbers prefer using the tub port, as it's not as restricted.
    I ALWAYS do it that way as long as the valve is 180 degrees symmetrical so it can be inverted. Doing it that way can avoid some nasty problems in the future.
    Dec 2013
    Maryland
    Thanks for your reply. Are you saying that the valve should be turned 180 so that the tub port is at 12:00?, instead of 6:00? The way mine is now, is that the tub port is facing at 6:00, with the tubing then going up to shower.
    And, what problems in the future are speaking about? I may have them at the present.
    Thanks again.
  1. HELP: Sprinkler RPZ valve and test cock port issue
    By Chrstine in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-08-2013, 03:14 PM
  2. Why does a 1" zone valve have a tiny 3/8 port?
    By Belmondo in forum Water Heater Forum, Tanks
    Last Post: 08-16-2012, 06:41 AM
  3. Putting tub spout on 4 port diverter valve with shower heads?
    By dujour in forum Shower & bathtub Forum & Blog
    Last Post: 01-02-2011, 03:10 PM
  4. Pex to Kohler 6 port Thermostatic Valve and general design q's
    By ijs12fly in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-05-2009, 05:22 AM
  5. Upgrading shower valve for existing galv. piping
    By Texas in forum Shower & bathtub Forum & Blog
    Last Post: 04-12-2007, 11:52 AM
