Thread: Uneven toilet flange
    DIY Junior Member jhr1986's Avatar
    Dec 2013
    DFW, Tx
    Default Uneven toilet flange
    Full disclosure, this is my first time replacing a toilet but it looked easy enough so I figured I could handle it. Now that I've got the old toilet removed I'm not so sure. The metal part of the flange is two pieces, but I'm not sure how the plastic part of the flange attaches to the soil pipe. I figure this flange has to be replaced, but I'm not sure how involved that will be. There is still one closet bolt to remove - it's soaking in PB blaster right now. So is this a fairly easy job that I should be able to handle or is it time for a professional? Here are a couple pics of the flange:
    Name:  toilet flange1.jpg
Size:  54.5 KBName:  toilet flange2.jpg
    DIY Senior Member Smooky's Avatar
    Apr 2011
    NC
    That looks like a push tite closet flange. You should be able to remove the screws and then pull it out. You could replace it with a new one.
    http://www.deerso.com/product/d35851...FU5o7AodgwMAzw
    http://www.homedepot.com/s/toilet+flange?NCNI-5
    If the toilet will fit over that flange without hitting it, and rocking, you could probably just put a new wax ring on, use some new flange bolts, and go. If the ring is steel and is rusting, then you should consider replacing it. It might be SS (stained, but that's okay). The ring should be attached to the plastic. Typically, it fits into a slot. If the PVC part moves easily, you'd probably want to deal with it, as you'd probably not get a good seal with a wax ring. Something like a Fluidmaster or Fernco waxless seal might work if the ring is solid.
    Ultimately, if the whole thing is loose or rusting, you'd be better off replacing the flange. The pipe should be coming up and be plumb, and if it were attached to the ring, it might be. But, they may have had too much angle on it, and over time, it popped out of the corroding ring.
  1. HELP: Uneven AS toilet bowl after install
    By axelf911 in forum Toilet Forum discussions
    Last Post: 05-05-2012, 02:20 PM
  2. Eljer toilet uneven - large flange, etc
    By in-mn in forum Toilet Forum discussions
    Last Post: 12-30-2010, 05:22 AM
  3. Uneven toilet flange in concrete
    By LocalHero in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-12-2010, 03:29 PM
  4. Uneven Flange
    By geandham in forum Toilet Forum discussions
    Last Post: 03-28-2008, 06:45 AM
  5. Uneven closet flange in concrete
    By Steven Michael in forum Toilet Forum discussions
    Last Post: 01-15-2007, 07:32 AM
