Results 1 to 5 of 5
Thread: rough-in drain heights
    DIY Junior Member anton's Avatar
    Dec 2013
    Massachusetts
    Default rough-in drain heights
    what is the correct rough-in drain height for a kitchen sink that will have a disposal?
    also....
    what is the rough-in drain height for a vanity?....
    and....my last question....today...
    what is the correct height for a washing machine outlet box?....we are install a stackable washer and dryer...full size.....
    thanx, in advance.....
    Plumber Sean Beck's Avatar
    Jun 2013
    Toronto, Ontario, Canada
    I would rough in a kitchen with disposal at around 15 inches.
    Vanity at around 18 inches.
    Usually have washing machine box at around 42 inches as the standpipe is required to be at least 2 feet, and be above the flood level rim of washing machine.
    That is sort of like asking how high is up...on the kitchen sink, it really depends on how deep the sink is and what else is going on in there.
    The vanity, depends on if there are shelves or drawers in there and the sink you choose. Note too, not all vanities are the same height, they vary from maybe 29" to where some people use kitchen counter height cabinets at 36", so the height there can vary a lot. Use a pedestal sink, and it becomes very bowl/pedestal specific where only one number works well.
    Your local codes will have some specifics on the required WM standpipe (Canada differs from most of the US as to size and placement).
    IOW, one general number may work for a bunch of situations, but may work for none of yours without compromises or significant problems.
    Nov 2010
    Maine
    I would get the cut sheet for the fixtures you plan to use and pipe accordingly. One of my big gripes is plumbers that rough in for fixtures using the close enough method. If you plan properly then you avoid the use of tailstock extensions, 24" flex supplies etc.
    Dec 2013
    Massachusetts
    sean...thanx for your input....i was an inch lower for the kit sink (which seemed low) and and inch higher for the vanity, but 18 or 19n seem in the right spot....and i had the outlet at 44....
    thanx again....
  1. Rough drain PVC wall opening heights - slope
    By chuck b in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-26-2012, 11:22 AM
  2. heights for supply and drain lines for bathroom sink
    By Steve_P in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-21-2010, 01:27 PM
  3. new sink, different heights
    By MWS in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-11-2008, 07:24 PM
  4. toilet heights
    By prd823 in forum Toilet Forum discussions
    Last Post: 11-16-2007, 09:44 AM
  5. Seat heights
    By tplarkin7 in forum Toilet Forum discussions
    Last Post: 05-27-2006, 02:34 PM
