Results 1 to 5 of 5
Thread: 2" sewage check valve recommendation
    DIY Member Hotbacon's Avatar
    May 2011
    Shillington, PA
    Default 2" sewage check valve recommendation
    I need to replace the check valve above our sewage ejector pump again (2nd time in 10 years). The first time the flapper had broken loose, thus defeating the purpose of the check valve. This time I'm just tired of hearing the loud banging and worrying what it's doing to the system. Can anyone recommend a good quality 2" sewage check valve? Slip on style is preferred to solvent weld.
    I googled silent sewage check valve, as is often recommended in similar threads, but am not sure which brands are good quality.
    Nov 2010
    Maine
    Replace it with what you can find locally and this time drill a 3/8" hole through the check before installing it.
    quote; this time drill a 3/8" hole through the check before installing it.
    And, if you do that, you might as well remove the check valve because it will be useless.
    Jan 2008
    It's a little pricey, but we have grown to love the A.Y. McDonald 2066s.
    Nov 2010
    Maine
    Yep, thought he was talking sump pump
  1. Question on 2" sewage check valve
    By jasper1372 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-27-2012, 11:50 AM
  2. New Campbell Mfg 2" Silent Sewage Check Valve slow to open
    By aswetich in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-02-2011, 11:36 AM
  3. How to drain the vertical 2" PVC sewage pipe above check valve?
    By DaveR in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-11-2011, 07:01 PM
  4. 2" check valve install for Sewage Ejector Pumpon
    By Rich_B in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-29-2008, 12:26 PM
  5. Detail question relating to sewage pit check valve and shut off valve.
    By Longwood in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-27-2007, 05:17 PM
