Results 1 to 5 of 5
Thread: Removing Stuck Shower Arm and Drain
    DIY Junior Member jgold47's Avatar
    Nov 2010
    Detroit, MI
    Default Removing Stuck Shower Arm and Drain
    This ties to my other thread, but wanted to keep them separate. I tried to replace the shower arm in my 1920's shower. I'm pretty sure the arm is not original however, but regardless, with all the pipe wrenches I could find, I couldnt get the thing to move at all.
    two questions -
    1. Wrench harder?
    2. does heating the arm help at all?
    part two, I am going to try and remove the drain from the tub as the tub uses an oldschool stopper system thats long gone and we have no way to plug the drain for a bath. I've got all the various tools the big box stores sell, including that gnarly extractor, but is there any chance that its somehow not threaded onto the waste pipe?
    Heating the arm will make it harder.
    Heating the fitting in the wall would make it easier, but that is hidden.
    In an old home like that, you may need to put a pipe wrench on it. Longer gives more leverage.
    And be prepared to go into the wall if that doesn't work.
    The tub drain should be threaded.
    1. use a bigger wrench
    2. It is threaded, but if the thread is "seized" you may snap the tube under the floor, so be judicious with your efforts and if it does NOT turn fairly easily, which it probably will not, be prepared to carefully cut it out.
    Jan 2008
    Before starting, be prepared for the possibility that you may have to open up the wall and have access from below to replace the tub shoe along with the waste and overflow assembly.
    Jul 2009
    North Vancouver, BC
    Quote Originally Posted by jgold47 View Post
    ...I couldnt get the thing to move at all...
    Man Hands are needed. Elbow grease a must.
    If you where my buddy here in Vancouver I'd give you a "Chirp" and say something like "Try putting your purse down first" or "Maybe the wrench is getting caught in your blouse" - One thing you get working the tools every day is a killer grip. Most homeowners do not have the strength to really make these tight fittings twist out.
    After "Chirping" my friend and failing (which Vegas has at 50/50 odds) I'd be looking for my "Big Wrench".
    I find cursing helps. LOL
    JW
  1. Removing Shower Drain Problem
    By saeefamily4 in forum Shower & bathtub Forum & Blog
    Last Post: 03-17-2013, 08:41 AM
  2. Removing Shower Stall Drain
    By posdrums in forum Shower & bathtub Forum & Blog
    Last Post: 10-28-2011, 02:23 PM
  3. Removing stuck handle from Moentrol Shower Body
    By thew60 in forum Shower & bathtub Forum & Blog
    Last Post: 01-30-2010, 02:02 PM
  4. Removing basement shower drain
    By crjcpm in forum Shower & bathtub Forum & Blog
    Last Post: 08-29-2006, 09:06 PM
  5. Removing old shower drain
    By gmilton in forum Shower & bathtub Forum & Blog
    Last Post: 10-10-2005, 09:04 PM
