Results 1 to 2 of 2
Thread: NEW TOTO DRAKE 1.6 G-MAX noisy fill?
    DIY Junior Member gottago's Avatar
    Dec 2013
    Default NEW TOTO DRAKE 1.6 G-MAX noisy fill?
    Hi, I just purchased a new Toto Drake 1.6 Gal flush with G-Max.
    I am not a Plumber but, after watching some "How to install video's" I decided to give it a shot.
    The installation went well, all of the internal parts in the tank were already in place. Just had to bolt the tank to the bowl. I also installed a new water fill line (Not the shut off valve).
    I used the larger wax ring. The toilet seated nice with no wobbles or leaks.
    My problem is after the flush the refill of the tank sounds like a cement mixer.
    The water line in the tank is lined up with the down tube. I noticed that there is water coming out from under the Blue G-Max unit. Is this normal or is it faulty? This water is making bubbles in the tank.
    I will add a photo.
    THANK YOU
    gottago
    Apr 2012
    New York, NY
    It's all good. Water falling off the fill valve is normal. It's part of the anti siphon function; it all falls in the tank anyway, and its not a problem. It's what it's supposed to do. As to noise, that's pretty normal as well. If you swap the fill valve for the korky 528mp max performance fill valve or the korky fits toto 5 28T fill valve it may be a but quieter, but the reality is it will give you some bubbling on refill. We have 2 and love them...
  1. Toto Drake: noise at end of fill
    By BradTinBC in forum Toilet Forum discussions
    Last Post: 06-09-2013, 06:09 PM
  2. Toto Drake fill valve leaking.
    By wolfdog170 in forum Toilet Forum discussions
    Last Post: 12-02-2010, 10:25 AM
  3. Toto drake fill valve issue
    By chopper in forum Toilet Forum discussions
    Last Post: 06-24-2008, 01:35 PM
  4. Noisy Fill of Toto Toilets
    By JimLF in forum Toilet Forum discussions
    Last Post: 07-29-2006, 02:43 PM
  5. Toto Drake Flush/Fill Pause
    By Jerome in forum Toilet Forum discussions
    Last Post: 11-23-2005, 06:49 PM
