Results 1 to 7 of 7
Thread: Sillcock with odd connection
    DIY Junior Member gregnoob's Avatar
    Aug 2009
    Virginia
    Default Sillcock with odd connection
    Good morning everyone,
    I've got a sillcock that is leaking like crazy. This started as a really slow drip and is now a steady stream. Trouble is that this house still has polybutylene piping which I have not got around to replacing and I've never worked with polybutylene before.
    I have no clue how these connections work and this one looks odd anyway. Can anyone tell me what is going on here connection-wise and how I can replace this without buying any special poly-b tools? I cannot find a shut-off for this spigot so I need to replace it ASAP. My initial plan had been to just cut the copper just behind the spigot and solder a new spigot on but I am afraid that the heat will melt the plastic piping.
    Photos below:
    Nov 2010
    Maine
    You either need special tools or a shark-bite fitting
    That's a frostfree silcock, and if you can identify the brand, you might be able to buy a rebuild kit for it. I'm surprised there's that much excess in the wall so that you can pull it out that far.
    Aug 2009
    Virginia
    I didn't know about shark-bite fittings. That looks like it would do the trick.
    Any tips on cutting the poly cleanly?
    Nov 2010
    Maine
    sharp utility knife
    I don't think sharkbites are recommended for poly-b...???? I've only ever seen advertised for copper, pex and cpvc..
    I'd turn the water off & try to take the silcock apart. You might just need a $2.00 washer. If not, either buy the proper tools, or call a plumber.
  1. PVC to Sillcock - Best Way?
    By TipsMcStagger in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-07-2013, 04:28 PM
  2. Sillcock Drama / S.O.S.
    By metalhead212 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-19-2009, 10:13 AM
  3. Sillcock blues. . .
    By Wryter in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-28-2008, 06:17 AM
  4. QuarterMaster Sillcock
    By bobsmith in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-03-2006, 06:47 AM
  5. sillcock
    By chipshot in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-17-2005, 07:59 PM
