Page 1 of 2 12 LastLast
Results 1 to 15 of 18
Thread: Replaced fill valve, no water fills in tank.
    DIY Junior Member Christopher Chan's Avatar
    Dec 2013
    Illinois
    Default Replaced fill valve, no water fills in tank.
    The other day I noticed after I flushed that my toilet wasn't getting any water in the tank. So, I went to the store and bought a new fill valve. After replacing the fill valve, water would of filled the tank, but didn't. I turned off the water and removed the pipe to see if I was getting water flow after turning the valve back on. still no water even after turning the valve back on. Could it be that I have a bad shut off valve or is the valve clogged? Need help! Thanks everyone for their future advice.
    Remove the supply line from the toilet and run the water into a bucket.
    If no water comes out of the supply, it's a problem with the wall shutoff.
    Dec 2013
    Illinois
    Yeah took off the supply, there isn't any water. Going to replace the shutoff valve. I live in a condominium building. Need to find the main water shut off and turn off the water tomorrow. Hopefully, it's just the valve and nothing bigger.
    Apr 2012
    New York, NY
    Quote Originally Posted by Christopher Chan View Post
    Just be careful that you're not violating your condo rules by doing your own plumbing in a multifamily building. Changing a toilet fill valve is no problem, usually. However, when you start changing the angle-stop in your bathroom, that's getting a little closer to an issue, depending on your condo's rules and your local plumbing codes,
    If you're talking about your own main water shutoff, again, that may be something you can rightfully play with; if you're talking about the shutoff to more than your unit, that might be a problem.
    Not trying to be a naysayer, just want to make sure you don't have problems with your condo association.
    DIY Senior Member dj2's Avatar
    Aug 2013
    California
    Your best course of action is to call the association first, if you don't have a shut off for your unit, or if your shut off is defective. Every condo bldg has its own arrangements, as you may have to shut off a valve that affects other units, to do your work.
    I recently worked on a condo and needed to replace the unit's main valve, which was defective. The association gave out notices to some 20 units, that the water will be shut off on a particular day and time. They gave me 2 hours to complete the job, which was enough, after 2 hours they turned the water back on and everything was fine. Then I was able to complete my work inside the unit.
    Sep 2013
    Most people today prefer the quarter-turn valve rather than the multi-turn.
    Before you replace the valve...what kind of hose is on the valve? If it happens to be a floodstop brand, that may be your problem. If when you take that hose of, if you have flow, then you'll know it's the hose, and not the valve.
    Apr 2012
    New York, NY
    Good catch, Jim. Christopher, I would go get a new braided supply hose (standard, not floodstop) and install it on your existing supply stop. You do well to change these out from time to time anyway, so it can't hurt. Turn on the water into a bucket and see if you have flow. If you do, then you're back in business.
    a Floodstop hose is the most likely reason for your problem.
    I agree with all of the above, and would just add a comment. Most likely the problem is the supply line, and even if it is not the problem, changing it would be very inexpensive and easy to do, and would either cure the problem or eliminate it. If this does not fix the problem then don't go any further without an OK from the condo assn.
    Dec 2013
    Illinois
    Sorry for the late replies everyone, well i just got a friend to come and check out the problem. We replaced the shutoff valve from the wall; after, we would think there would be water flow. well there's still no water coming through. So what do you think the problem is now? I think the only problem that this could be a clog in the pipe somewhere, because everything else in the bathroom is getting water flow, besides the toilet. Any suggestions would be nice and appreciated. Thanks again.
    ps, i forgot to also add that i got the approval from the condo association. I even asked them if they had this problem with any other units in the building, they said that i'm the only person with this issue, and they were no help at all. They also mention that since it's just my unit that has the problem, they wouldn't be responsible for any of the inconvenience or compensation to the problem. Do you think that they could be some what liable?
    Sep 2013
    Did they "mention" that spontaneously, or in response to something you said along those lines?
    I expect that agreements differ, what they are telling you is common.
    http://articles.chicagotribune.com/2...ation-coverage
    Regarding your plumbing, was the plumbing shutoff to your unit easy to access? Is the plumbing that you saw copper, or galvanized? Old building? Are you above another unit? I don't know how I would proceed, but those with ideas might be inspired by some more information.
    Jan 2008
    Last one I saw was a frozen pipe.
    Did you check for water at the valve with, or without the hose on? If the hose was on, it could easily have been the hose. Don't remember if you ever clarified if the hose was a FloodSafe one or not...those have an internal valve that may be stuck, or closed, thinking there was a leak.
    Depending on how the water is run, it could be a frozen pipe, but it could be a major problem if it IS that, as depending on how hard of a freeze, it may split the pipe or a fitting, and when it defrosts, major damage can occur.
    Dec 2013
    Illinois
    I'm going to take some pictures of the toilet, tank, valve, and the hose. Sorry, I apologize that I do not know much about toilets and plumbing. You guys are very informative and I'm lucky to have help from y'all. Happy New Years to everyone and be safe.
  1. Water use - hissing G-Max Korky 528 fill valve - Quiet Fill
    By urdrwho in forum Toilet Forum discussions
    Last Post: 09-23-2012, 04:15 PM
  2. Toilet fills when you pull lever and water goes down after the tank fills.
    By sxch14 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-18-2011, 12:16 PM
  3. Replaced Fill Valve and toilet won't stay full
    By bikindi in forum Toilet Forum discussions
    Last Post: 07-26-2007, 08:10 AM
  4. tank fills even though stop valve is closed
    By medleyjg in forum Toilet Forum discussions
    Last Post: 04-27-2006, 03:45 AM
  5. Replies: 1
    Last Post: 08-13-2005, 02:54 AM
