Thread: transitioning from galvanized to copper
    Default transitioning from galvanized to copper
    Gonna tear out some old galvanized and replace with copper. Cant replace it all so I 'm gonna have a 3/4"galvanized to 3/4" copper transition. Figured I'd use a 3/4" brass threaded coupler off the galvanized pipe, then a 6" brass nipple, then a copper FIP to sweat fitting and continue on with my rigid copper. Lotta connections there, but is there a better way? The existing plumbing has some dielectric unions where others have transitioned to copper but they show signs of corrosion.
    DIY Senior Member Smooky's Avatar
    Apr 2011
    NC
    I would not bother installing dilectric unions. They close off very quickly.
    Junk.
    I've been using 6" brass nipples for transistion.
    It's also one reason I don't like leaving any galvanized in a building once I've started replacing with copper. Any time you transistion, it's a probem.
    Thanks Terry, Unfortunately I don't have the option of removing all the galvanized in this situation.
  1. Copper/Galvanized Corrosion
    By Tyson in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-20-2010, 06:20 AM
  2. Galvanized, Brass and Copper
    By asktoknow in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-30-2009, 06:24 PM
  3. Black>Galvanized>Copper
    By jpiazza in forum HVAC Heating & Cooling
    Last Post: 02-18-2008, 07:21 AM
  4. Galvanized to Copper
    By EdPDX in forum Shower & bathtub Forum & Blog
    Last Post: 06-08-2007, 01:07 PM
  5. converting galvanized to copper
    By Henry Ramsey in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-14-2007, 09:33 AM
