Results 1 to 2 of 2
Thread: Need a ball valve recommendation
    DIY Member techinstructor's Avatar
    Apr 2009
    North Carolina
    Question Need a ball valve recommendation
    Can anyone recommend a brass ball valve that will last? We replaced on that we had used for about 1 1/2 years with the same brand. The second one has only been installed for about 3 months and it is already leaking (just a drip) from the top of the valve.
    I've been buying them at Lowes, American Valve brand.
    These are not cheap but I'd be willing to pay more for one that will last at least a few years. Any suggestions?
    They are not really designed to be a valve that is continually turned on and off. Doing that WILL wear the stem packing seal, which is what is happening to your valves. There is a packing nut under the handle which might be able to be tightened to stop the drip, but it will eventually come back. You need a "faucet" designed for constant usage.
  1. Check Valve or Ball Valve to HOLD PRIME
    By Mike Pastorelli in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-21-2012, 03:59 PM
  2. Ball valve
    By novice-man in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-06-2009, 09:28 PM
  3. Combo ball valve/check valve for ejector pump...
    By hhcibtpaun in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-17-2009, 12:27 PM
  4. ball valve
    By gfe76 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-15-2008, 05:26 PM
  5. Ball Valve Question?
    By jk60 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-04-2006, 09:44 PM
