Results 1 to 6 of 6
Thread: brass vs. copper PEX fittings
    Default brass vs. copper PEX fittings
    Can someone explain the difference? Why choose one over the other. I see both being used out in the field.
    Brass, and plastic, fittings usually have a thicker wall, so the openings are smaller than for copper fittings. They may also "crystallize" and become brittle.
    Brass may also have lead in it, and that is becoming an issue.
    Only to those who write absurd laws or who are paranoid.
    Didn't say I was worried, but, the codes prohibiting it are slowly creeping across the country, and everyone dealing with the industry then MUST deal with it.
    DIY Senior Member craigpump's Avatar
    Apr 2012
    ct
    As of Jan 1 we all have to deal with it and pass the increased costs on to our customers. The taxpayer takes it in the backside again.
  1. Brass Nipples vs. copper w/ sweated NPT fittings?
    By speede541 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-13-2013, 05:38 AM
  2. Can I mix PVC pipe with non-PVC fittings? Are there higher quality copper fittings?
    By Upton O Good in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-07-2013, 05:57 PM
  3. Brass Fittings
    By glnow in forum Irrigation / Sprinkler Forum
    Last Post: 10-12-2009, 05:49 AM
  4. Brass fittings
    By Ed from chicago in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-26-2005, 06:48 AM
  5. How tight - copper to brass threaded fittings
    By tfratzel in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-09-2005, 08:57 AM
