Results 1 to 5 of 5
Thread: shower valve plumbing question
    DIY Junior Member ragtop68rs's Avatar
    Dec 2013
    Grand Rapids,Mi.
    Default shower valve plumbing question
    Guys, I'm starting a master bath remodel. For my shower I want to use the moentrol 3320(IPS)or 3330(CC) valve. My plumbing is all pex. Could I use either one of these and just use adapters to change to pex? Would one be better or easier to use than the other? Thanks, John
    Not much difference between the two.
    The tub spout needs either copper or pipe.
    No PEX or PEX fittings to the tub spout.
    The valve must be sturdy in the wall. PEX can allow too much flex, so if running PEX, secure the valve in there solid.
    I just installed two moentrol valves this week in a remodel. Not much in the way of mounting provided on the valve, so I "stub" them out with copper to give me something to mount with. then you could transition to pex if you so desire.
    Here's a pic terry showed me recently of a tub install. I don't carry a camera. Note his rough in. Do it like he did, securing the valve with copper pipe. just transition to pex below the lower 2 x 4 brace he put in.
    Dec 2013
    Grand Rapids,Mi.
    Thanks guys, that is what I will do.
  1. Question about plumbing a Riobel thermostatic valve - Help!
    By TimCanada in forum Shower & bathtub Forum & Blog
    Last Post: 08-14-2011, 02:52 PM
  2. Shower Plumbing Question
    By az1324 in forum Shower & bathtub Forum & Blog
    Last Post: 11-19-2008, 06:44 AM
  3. using unions in shower valve plumbing, yes or no?
    By macleod in forum Shower & bathtub Forum & Blog
    Last Post: 10-25-2008, 07:36 AM
  4. Shower plumbing question
    By mrmichaeljmoore in forum Shower & bathtub Forum & Blog
    Last Post: 07-19-2007, 07:05 PM
  5. Replace shower Plumbing Valve assembly shower head 2 knobs
    By scri8e in forum Shower & bathtub Forum & Blog
    Last Post: 12-30-2006, 10:24 AM
