Results 1 to 1 of 1
Thread: Takagi T-Kjr flashing 4 code
    DIY Junior Member cbytes's Avatar
    Dec 2013
    montana
    Default Takagi T-Kjr flashing 4 code
    I have a Takagi T-Kjr with a 4 flash code after the water runs and stops, I have to hit reset button to get hot water again and it will stay running as long as I don't shut the hot water off but as soon as I do I get a 4 code after the fan purges.
    Steps I've taken:
    1. replaced pressure switch.
    2. cleaned burner and flu according to Takagi tech support. (done it twice)
    3. changed switch #6 to on (outside) even though it's inside.
    4. cleaned fan
    Relevant info:
    its a 2 year old LP heater and was working flawlessly until i decided to take out the pressure switch to put in to an identical unit for my floor heat, that is when i started to get the 4 code, even after swapping back the pressure switch and putting a new one in, I still get the 4 code. Any help would be great.
    Update:
    I tried blowing off the dust from the fan blades again and the heater worked as it was suppose to for about 5 or 6 times then it stopped working and started flashing a 4 code again. Is there any type of a sensor that I am missing that needs to be cleaned ?
    Update:
    after many days of waiting I finally got an email from a service tech and the suggestion he gave solved it. Make sure the tube for the pressure switch is in the L for low pressure and not the H for high pressure. Bam !!! it's been working fantastic for months.
  1. Noritz NR71: What does the flashing code mean?
    By mptrauber in forum Tankless Water Heater Forum
    Last Post: 04-30-2012, 05:53 PM
  2. Takagi T-K2 Error Code 11
    By halogen25 in forum Tankless Water Heater Forum
    Last Post: 01-30-2012, 01:59 PM
  3. Takagi JR error code 12
    By aksmieja in forum Tankless Water Heater Forum
    Last Post: 12-09-2011, 08:45 AM
  4. Takagi KD-20 Error Code 21
    By chiron47 in forum Tankless Water Heater Forum
    Last Post: 12-24-2010, 11:43 AM
  5. Takagi Jr. Error code 12
    By Bernie Mac in forum Tankless Water Heater Forum
    Last Post: 06-27-2010, 07:51 AM
