Thread: Plastic bolts too tight
    DIY Junior Member MichaelNJ's Avatar
    Dec 2013
    NJ
    Default Plastic bolts too tight
    I'm trying to replace two toilet seats installed by the previous homeowner. Both are held in place with plastic bolts/winged nut but I am unable to loose them even a little. With a flat-head screwdriver from up top and pliers pinched on the nut underneath and maximum elbow grease, I've only succeeded in starting to strip one of them. Even trying to move the nut has proved fruitless.
    It feels like they are all deadbolted in. Can anyone offer some help, it would be greatly appreciated. This should be a five minute job, but it has me cursing up a storm!
    Did the new seat come with new ones? If so, don't worry about it, either keep torqueing them until they break, or cut them off (need to be careful not to scratch the toilet, though). They could have used some thread locking compound on them, as those sometimes are hard to keep tight otherwise.
    Jan 2008
    More often than not is is easier to hack saw the seat mounts horizontally just above the bowl, using care not to touch the porcelain.
    Just drill down the center of the bolt with a 3/8" or slightly larger drill bit and the nut will fall off with the bottom of the bolt.
  1. Well Cap Bolts
    By HWMonkey in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-24-2012, 06:01 AM
  2. Plastic to plastic threaded fittings... use teflon or not?
    By DavidTu in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-09-2010, 03:31 PM
  3. weather tight 3/4" plug for a plastic timer box
    By rdtompki in forum Electrical Forum discussion & Blog
    Last Post: 12-06-2007, 07:41 PM
  4. Tank installation - how tight is "too tight"?
    By kissthekohler in forum Toilet Forum discussions
    Last Post: 08-28-2005, 06:25 PM
