Thread: ABS joint gave out, now to fix it...
    DIY Junior Member oh Canada's Avatar
    Dec 2013
    Ontario
    Default ABS joint gave out, now to fix it...
    I've got an ABS tee that joins my main floor laundry washer into the main drain in the basement. For a long time there would be a very slight leak when a load of laundry was washed. When the washer dumped all the water out into the drain there would be a few drips of water at the joint where the tee joins with the main drain pipe going into it from the second floor. The tee's joints at the washer and the outbound end of the main drain were, and are still, 100%. Tonight that "few drips" turned into a torrent after I flushed the toilet upstairs. I took a look at it and the whole "weld" of the joint is blown. The whole thing has severed at the "weld". Both the pipe going into the tee and the tee itself are solid, no cracks. But they are no longer attached. I'm not sure how that happens but I know that the previous house owner used it as a rental flop and did next to nothing to maintain the house (and what he did was functional but not proper) Maybe he used PVC glue on the ABS or something as I've heard that will work temporarily but won't last. Anyhow, my question is this: Can I separate the pipe from the tee, clean up the excess solvent, re-apply fresh solvent and then join them back up again? Given the layout of things putting in new pieces would be a difficult task.
    Btw: Nice forum you have here
    From you description it appears the pipe is already separated from the tee. If so, then you may be able to just reglue it with the proper cement.
    Dec 2013
    Ontario
    It has separated. I just didn't know if re-attaching those two specific pieces instead of replacing them was a viable option. Thank you "Licensed residential and commercial plumber".
    Jan 2008
    The trick will be to clean the attachment points so that it will not happen again. Use sandpaper to clean off any foreign materials and cement residue, then use proper ABS cement on both sides of the joint when refitting. Hold the joint together tightly for a minute after bottoming the pipe in the fitting. The cement chemically bonds the fitting to the pipe, so it is important to do it correctly with the proper cement.
  1. My cat gave me this idea...really
    By Cookie in forum Joke of the day
    Last Post: 04-18-2012, 07:29 AM
  2. can't get joint hot enough
    By backwaterdogs in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-13-2011, 01:59 PM
  3. When to Redo a PVC joint
    By TedO in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-02-2011, 06:48 PM
  4. Softeners gave me high blood pressure
    By etower007 in forum Health and Wellness Forum
    Last Post: 03-11-2011, 03:41 PM
  5. wiped joint
    By cwhyu2 in forum Toilet Forum discussions
    Last Post: 09-01-2007, 01:51 PM
