Thread: Panasonic Inline FV30NLF1
    DIY Senior Member rshackleford's Avatar
    Oct 2005
    Eastern Montana (The Bakken)
    Default Panasonic Inline FV30NLF1
    I would like to use the FV30NLF1 to vent my master bath and bedroom. Basically the master bath and bedroom are one big room. The bath has a shower, free standing tub, and stool. The bath is 6' wide x 20' and the bedroom is 18' x 18'. They both share the same open vaulted ceiling.
    I am having troubling finding a 6" vent for the eve and I have a very tight heel on the truss to try to get the vent through. I would like to use about 15' of 6" al flex duct, a 6" x 4" reducer, 6' of 4" duct, and a 4" eve vent hood.
    Thoughts?
    rshackleford
    A 4" round duct has nearly 55% less area than 6" round. So, the fan would have the equivalent of a 4" duct, and maybe less depending on elbows and the friction from the distance traveled and the reducers. The spec sheet usually indicates the performance of the fan with various allowable ductwork and sometime sizes. If those reductions can still give you the desired airflow volume, it should work, but my guess is, it will reduce the output too much to be effective for your application.
    Oct 2005
    I design pumps and was hoping the manufacturer would have a curve for the fan like a pump curve but I haven't found one.
    rshackleford
    I did not look at this particular Panasonic fan, but on the last one I installed, it had some detailed charts on air flow based on the duct sizes and length...have you dug out the spec sheet? I'm pretty sure it was also in the installation instructions, which, if you haven't bought it yet, are all available on their website. Some of them have DC motors, and can adjust to maintain a desired airflow (within limits), so it may be more versatile than some other choices.
  1. Panasonic Bath Fan Wiring
    By dmwesq in forum Electrical Forum discussion & Blog
    Last Post: 08-17-2013, 09:01 AM
  2. Panasonic bath fan
    By Ed from chicago in forum Electrical Forum discussion & Blog
    Last Post: 12-08-2012, 04:16 AM
  3. Panasonic Vent Fans
    By chefwong in forum Remodel Forum & Blog
    Last Post: 09-27-2011, 05:19 AM
  4. Panasonic FV-13VKM2
    By T_Hartigan in forum Shower & bathtub Forum & Blog
    Last Post: 12-01-2009, 01:56 PM
  5. Which panasonic bathroom fan?
    By fidoprincess in forum Remodel Forum & Blog
    Last Post: 07-26-2008, 08:40 AM
