celife
I recently purchased this assembly to repair a leak in my Jacuzzi: http://www.spadepot.com/shop/Heater-Union-Split-Nut-Assembly---2-P797C717.aspx
As I wait for it to arrive, I have 3 questions related to its installation:
1. Will the installation of this replacement assembly require PVC Primer & PVC Cement?
2. In the image “jacuzzi-leak-far.jpg” you can see that there doesn’t appear to be much space for the pipes to the right of this assembly to move to allow enough space or “give” to remove the old assembly and replace the new one. In your experience, do you think there will be space enough to remove it?
3. My first attempted solution was to stop the leak with JB Weld WaterWeld, which you can see in the pic “jacuzzi-leak-near.jpg”. I am wondering if loosening the black union will cause the white piece to its right to crack because the two or now fused (to some degree) by the WaterWeld. Or, do you think the WaterWeld seal will break apart under the torque of the black union being loosened?
