Results 1 to 3 of 3
Thread: 3 questions regarding installation of a replacement assembly to stop a Jacuzzi leak.
    DIY Junior Member celife's Avatar
    Dec 2013
    Crockett, CA
    Default 3 questions regarding installation of a replacement assembly to stop a Jacuzzi leak.
Size:  71.4 KBName:  jacuzzi-leak-far.jpg
    I recently purchased this assembly to repair a leak in my Jacuzzi: http://www.spadepot.com/shop/Heater-...-P797C717.aspx
    As I wait for it to arrive, I have 3 questions related to its installation:
    1. Will the installation of this replacement assembly require PVC Primer & PVC Cement?
    2. In the image “jacuzzi-leak-far.jpg” you can see that there doesn’t appear to be much space for the pipes to the right of this assembly to move to allow enough space or “give” to remove the old assembly and replace the new one. In your experience, do you think there will be space enough to remove it?
    3. My first attempted solution was to stop the leak with JB Weld WaterWeld, which you can see in the pic “jacuzzi-leak-near.jpg”. I am wondering if loosening the black union will cause the white piece to its right to crack because the two or now fused (to some degree) by the WaterWeld. Or, do you think the WaterWeld seal will break apart under the torque of the black union being loosened?
    1. It will to connect the pipe to the "tailpiece"
    2. No way to tell because we cannot see the rest of the piping.
    3. The Water Weld may NOT crack, but since you have to cut the pipe anyway, cut it first and it will rotate as you remove the nut.
    Dec 2013
    Crockett, CA
    Thanks for your feedback.
  1. Vanity drain assembly installation method?
    By Designie in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-14-2011, 08:28 PM
  2. Weil McLain Combustion Chamber Replacement Assembly
    By fatdaddy in forum Boiler Forum
    Last Post: 01-04-2011, 09:03 AM
  3. leak at bypass valve assembly
    By Mikegranado in forum Water Softener Forum, problems, installation and reviews
    Last Post: 07-20-2010, 11:28 AM
  4. shower screwdriver stop assembly leak
    By CluelessInSeattle in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-10-2007, 07:25 PM
  5. Cadet 3 flushvalve assembly installation
    By jrswartz in forum Toilet Forum discussions
    Last Post: 05-02-2007, 10:14 AM
