Results 1 to 2 of 2
Thread: Softener and Iron filter replacement recommendations
    DIY Junior Member pdesourdy's Avatar
    Dec 2013
    Ontario
    Default Softener and Iron filter replacement recommendations
    Hi all,
    Longtime lurker posting for first time. I'm looking to replace a greensand iron filter and water softener that are both about 16 years old. Currently 2 people in the household but eventually will be 4.
    Analysis results from private lab are as follows:
    Hardness mg/L 316 (18 gpg)
    pH 7.7
    Total Dissolved Solids mg/L 584
    Sulphide mg/L Not detected ( less than 0.02)
    Calcium mg/L 92.3
    Iron mg/L 2
    Magnesium mg/L 20.8
    Any thoughts on the following to replace my greensand filter and softener:
    Fleck 5600SXT 48,000 Grain (1.5 cu ft) softener http://www.aquatell.ca/water-softene...er-48000-grain
    Hydrotech AIO 1.5cu ft chemical free iron filter http://www.aquatell.ca/iron-water-fi...ter-system-1.5
    Any thoughts would be much appreciated
    Phil
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    The chemical free filter uses air to oxidize the iron and then a media to remove it. I would ask what type of media and check to make sure you have the flow rate to properly clean the media. Iron medias can be very heavy and not having the proper flow rate may cause it to premature fail due to improper flow rate.
  1. Iron Filter AND Water Softener?
    By TaraC+3 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 11-28-2013, 06:01 AM
  2. Iron Filter / Water Softener - how to choose
    By kellerdc77 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 01-14-2013, 04:18 PM
  3. Iron Filter/Water Softener need advice
    By keithw1977 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 09-27-2012, 10:45 AM
  4. Water softener & sediment filter recommendations?
    By chuck b in forum Water Softener Forum, problems, installation and reviews
    Last Post: 08-20-2011, 09:25 AM
  5. Iron filter vs. water softener
    By rburt5 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-24-2008, 11:25 AM
