Results 1 to 9 of 9
Thread: I screwed up, tiled my floor too tight for the closet flange to sit flush
    DIY Junior Member annagibs's Avatar
    Sep 2013
    Cleveland
    Default I screwed up, tiled my floor too tight for the closet flange to sit flush
    Hi all I'm having problem that I hope you guys can solve
    I didn't account for the bevel underside of the flange so now it sticks up, rather than being flush.
    What are my options?? Flange without bevel? Somehow chip the tile away? What's best? Thanks in advance
    Sep 2013
    1. Sticks up how far?
    2. Is it sturdy and stable/
    As long as the toilet sets over the flange, you will be okay.
    There is quite a bit of space under a bowl.
    Sep 2013
    Cleveland
    This would have been too high.
    Sep 2013
    Cleveland
    Yes way too high! Went back to the depot for a grinder and found the stainless flange with a smaller bevel. It still isn't completely flush with the tile it lips up maybe 1/8 on one side. Is that going to cause me any problems??
    If the toilet fits over it without hitting (do a dry fit), and, you can anchor the ring to the subflooring (you might want to put a washer or shim or something to keep from deforming the ring), it will work.
    FWIW, Sioux city makes some they claim will fit flush in that situation...I haven't seen one in person, but supposedly, it's got a nice clean 90-degree angle on the bottom. You do want one with a SS ring, not the painted steel, though (and Sioux City does make them, too).
    Jan 2008
    If you really want it to lay flat, a diamond blade in a 4" angle grinder will allow one to grind around the pipe to fit as needed.
    DIY Senior Member bluebinky's Avatar
    Aug 2011
    Santa Clara, CA
    You mean grind the tile or pipe? Wear a dust mask when grinding tile...
  1. Closet Flange level to finish floor but gap to sub floor
    By boardryder in forum Toilet Forum discussions
    Last Post: 05-18-2011, 11:05 AM
  2. Closet flange install in basement floor
    By jfhardy in forum Toilet Forum discussions
    Last Post: 10-07-2009, 06:52 AM
  3. Closet Flange with remodel floor
    By Mongo in forum Toilet Forum discussions
    Last Post: 12-06-2006, 03:33 PM
  4. closet flange and new floor
    By xj-boonie in forum Toilet Forum discussions
    Last Post: 06-23-2006, 09:37 PM
  5. Attaching ABS flange to tiled concrete floor
    By koa in forum Toilet Forum discussions
    Last Post: 04-22-2005, 08:34 PM
