Results 1 to 2 of 2
Thread: Air check valve replacement and brine float questions
    DIY Junior Member 14kbiz's Avatar
    Jun 2013
    NJ
    Default Air check valve replacement and brine float questions
    Regarding the float in the brine tank, how low should it drop? I have a normal amount of brine in my tank but the float does not drop down as low as the brine level. Is this normal? I'm asking because my softener is drawing brine sporadically. I think the real problem is the air check valve and I want to replace it. What's the easiest way? What stage of the cycle should I set when replacing the valve and do I need to relieve the pressure from the softener before removing the old valve?
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    When you first posted, I thought about the 2300 safety float assembly sucking air. The float is a safety devise to shut off the flow of water if it gets too high. It should be just below the overflow elbow on the side of the brine tank. As long as the unit is not in a regen cycle, you can replace the safety assembly. You do not have to change the entire float assembly just the 2300 assembly.
  1. Fleck 2510 - Brine Pick Up Float Valve Malfunction - New Valve No Help
    By genehil in forum Water Softener Forum, problems, installation and reviews
    Last Post: 04-19-2013, 06:26 AM
  2. Elan / brine barrel float switch??????????????
    By bsa_bob in forum Water Softener Forum, problems, installation and reviews
    Last Post: 03-22-2011, 08:40 AM
  3. Brine Tank Safety float setting
    By farmboy101 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 06-06-2010, 11:15 PM
  4. Sump Pump Replacement and Check Valve
    By wraujr in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-06-2010, 01:52 PM
  5. Sump Pump Odor and Check Valve Questions
    By fracai in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-24-2008, 07:39 PM
