Results 1 to 10 of 10
Thread: American plumber water softner
    DIY Junior Member Outside42's Avatar
    Dec 2013
    Nj
    Default American plumber water softner
    May some info could help us ,we had water softener and neutralizer installed water was acidic also hard they said to use blue bag salt that's what we use the problem is the water taste like crap salty and nasty we had all our old pipes removed and replaced with pex what would you guys say thanx
    Nov 2010
    Maine
    I would say something ain't working right.
    Dec 2013
    Nj
    Where do I start
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    Does it taste salty just after a regen? What is the hardness set at? How much water is in the brine tank?
    Jan 2012
    California
    A softener should have a minimal affect of the tase of water. If you are getting a truly salty taste to the water, it should only occur after a regeneration if there is a problem with the softener and should clear up after running the water for a short amount of time. if you get salty water in the water heater, it will take considerably longer to get that cleared due to dilution issues. If your system produces salty water, you have a problem. Extended salty taste out of a softener would usually indicate a bad or missing riser o-ring, or a short manifold assembly.
    We need more information to help you. A picture of the unit, water source (well or municipla), how old the unit is etc.
    Hope this helps!
    Dec 2013
    Nj
    It is a well .always salty taste and has a metal taste .nutr.is w 4 15a nf. Softener is w 430 f. Both American plumber
    Jan 2012
    California
    Always salty water from a well fed softener would probably be the well and not the softener. If a softener malfunctions and causes salty water, that will go away fairly quickly. Try bypassing the softener and see if anything changes.
    Dec 2013
    Nj
    Did bypass water taste like well um water
    Jan 2012
    California
    Do you have a water report? Calcite and corosex can give the water a mineraly taste, even metallic. The softener adds sodium to the water in place of the Calcium, magnesium, etc. It takes a lot of sodium in the water to afffect taste.
    Did they put the neutalizer before or after the softener?
    What water testing equipment do you have? TDS meter, hardness test? anything?
    Dec 2013
    Nj
    Yes I just sent it out .I know it was hard water with lots of magnesium should I try by passing water softner and only use nutrilzer ? I know we keep using salt and I put calcite in nutrilzer 6 months ago
  1. Can Anybody Here Read Water Test Results? Need Help Deciding on Water Softner Type.
    By kozaz in forum Water Softener Forum, problems, installation and reviews
    Last Post: 03-15-2010, 11:40 PM
  2. Water softner
    By rblutonsr in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-04-2008, 06:05 PM
  3. Culligan mark 100 water softner water flowing to brine line all the time
    By seahawk99ca in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-27-2007, 09:35 AM
  4. water softner ??
    By alfred f in forum Pumps and Tanks Well Forum & Blog
    Last Post: 11-22-2006, 05:16 PM
  5. American Plumber
    By jimbo in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-19-2005, 08:38 AM
