Results 1 to 7 of 7
Thread: Small water heater recommendation
    DIY Junior Member nmlaz's Avatar
    Oct 2011
    Vancouver, WA
    Default Small water heater recommendation
    Hello -
    I am finishing a bonus room with 1/2 bath / powder room and a bar that will have a sink. I was looking at small water heaters and thought I had it all figured out but would appreciate your input.
    First, everything is wired (120v dedicated) and plumbed. I was looking at the Ariston 2.5 Gal HERE Or this GE HERE
    In contrast what about 120v tankless? Like this one HERE Made in USA is bonus for me too.
    This room will be used for watch parties and just hanging out... you know, man cave stuff... just not sure if I should get the bigger size (4 gal) or if there is another small water heater that would be better. Actual hot water needs other than washing hands and glasses / small dishes from time to time would be limited.
    Any high quality small WH's out there? Is this one junk???
    Thanks for your recommendation.
    Nick
    Sep 2013
    Could Nick use the cable that he ran for a dedicated 120 VAC water heater circuit for 240?
    Depends on the gauge...and what the WH required for current. 120vac circuit could be run in 14g but if it's a 20A, needs to be at least 12g, so you're limited to the gauge wire as to what breaker you can use.
    Oct 2011
    Vancouver, WA
    I didn't run anything less than 12/2, which is what this circuit is. I thought about running 240 but for what we'll be using it for (mostly washing hands) I figured the 120v circuit would be fine.
    Any good little units out there?
    Thanks so much!
    Sep 2013
    Quote Originally Posted by nmlaz View Post
    240 can run fine on 12/2 just as well as 120 VAC. The question I was asking is if are you allowed to use a white wire as a hot if you mark it somehow. It used to be allowed. If so do you have enough space in your breaker panel for a 240 breaker? That would let you select from a lot more water heaters.
    Oct 2011
    Vancouver, WA
    Quote Originally Posted by Reach4 View Post
    Yes sir, that is legal here. I have a few circuits wired that way. I also have plenty of room for the breaker....however, my original question was for recommendations on a 120v WH ... I realize I would have more options and probably be happier with 240v if I had a higher demand, but I don't. I'm really just going to be using it for hand washing 90% + of the time.
    I guess in my original post, I should have been more clear. I am more worried about reliability, chances of leakage and overall quality as opposed to the recovery, temp rise etc of the WH's in question.
    From what has been said previously, the difference between electric WH's is usually very small, unlike the more complex gas-fired ones. Pick one in a size and power requirement that will suit your needs. A line-voltage one will take longer to recover, but that may not be an issue, and can be compensated by picking a larger one. It's all about how much you need, and how often.
  1. Recommendation for residential gas water heater
    By Fubar411 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-08-2011, 01:39 PM
  2. Water Heater Recommendation
    By Dee in SC in forum Water Heater Forum, Tanks
    Last Post: 03-18-2011, 01:07 AM
  3. Water Heater Recommendation
    By Podo98 in forum Water Heater Forum, Tanks
    Last Post: 06-08-2009, 04:43 PM
  4. Hot Water Heater Recommendation?
    By fineline in forum HVAC Heating & Cooling
    Last Post: 12-26-2007, 07:35 AM
  5. DV Water Heater Recommendation.
    By ygdron in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-16-2006, 09:36 AM
