Results 1 to 6 of 6
Thread: two faucets one drain sink...can i use faucets with standard popup drain?
    DIY Junior Member naadimre's Avatar
    Nov 2013
    New York
    Smile two faucets one drain sink...can i use faucets with standard popup drain?
    this is the sink we're installing. we're using the hansgrohe puravida faucets. i was wondering in this setup, do we just connect one of the popup drain assemblies and the other will be a dummy? the plumber seemed to think that since the drain is offset and not directly in front of the faucet, a touch or push drain would be better and not to use the popup drain at all.
    thank you!
    Nov 2013
    New York
    i posted the wrong picture, this is the 39 inch sink. we're installing the 47 inch sink. thanks.
    DIY Senior Member Smooky's Avatar
    Apr 2011
    NC
    You could go with a Push Pop-Up or just a flat strainer.
    Nov 2013
    New York
    just realized, i already purchased one faucet that has the pop-up assembly included and another that is without the assembly. looking at the faucet with the pop-up, the ball rod will be WAY too short. what do people normally do in this situation? is it easy to find a replacement extra long ball rod? the distance to cover will actually be about 12-13 inches!
    The problem with a longer rod is that it has to travel a much longer distance to move the popup plug open and closed. Few faucet popups have room for that much travel. But to extend the rod, you use a proper sized "rod coupling with two set screws" and a piece of plain rod the proper length.
    He could drill the sink and add the pop-up in the middle, centered between the two faucets.
    Or, I like what he mentioned about the push drain covers.
  1. Bathroom faucets shut-off valves - also Delta faucets
    By Donald Allen in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-16-2013, 08:15 PM
  2. American Standard Shower fittings and faucets
    By Mahnrut in forum Shower & bathtub Forum & Blog
    Last Post: 05-06-2009, 06:05 AM
  3. Single-Handle Bath faucets without drain
    By Dexter in forum Shower & bathtub Forum & Blog
    Last Post: 09-04-2008, 07:01 AM
  4. Boiler drain faucets for washer
    By Peg in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-31-2005, 02:44 AM
  5. New Moen Faucets - Leaking Drain
    By frodnew in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-29-2005, 04:07 PM
