Results 1 to 4 of 4
Thread: Vintage Crane Siwelclo 1935 toilet repair - need help
    DIY Junior Member sportsgaleliza's Avatar
    Dec 2013
    chicago
    Default Vintage Crane Siwelclo 1935 toilet repair - need help
    I am trying to repair a toilet that is older than many of the users of this forum, i imagine.
    I have a Crane Siweclo toilet from about 1935 made by Trenton Potteries.
    I am getting water leaking between the tank and the bowl.
    I tried making a gasket and also putting in a wax ring but neither worked. If i drain the water slowly from the tank to the bowl it is fine but when i flush, water starts to drip from under the tank.
    I am attaching photos of the toilet - - the area where the tank connects to the bowl is very unusual and has an overal 3 1/4" by 41/4 opening.
    Any ideas on this? Thanks.
    Crane SIWELCLO
    Yakima WA
    One might ask why you are trying to repair an 80 year old toilet that probably uses 7 gallons of water per flush when there are dozens of up to date low flow toilets readily available for likely less than your repair parts will cost. But, maybe you still drive that '35 Ford. LOL
    DIY Senior Member Reach4's Avatar
    Sep 2013
    I wonder if one of those Fernco Wax Free Toilet Seals would do it. They have an adhesive top that you would stick to the tank. http://www.fernco.com/plumbing/wax-free-toilet-seal
  1. Crane faucets from 1930 - desperate to repair....
    By KinLI in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-28-2013, 04:04 PM
  2. Repaired broken vintage toilet tank with fiberglass cloth and epoxy!
    By ExecutiveRanch in forum Toilet Forum discussions
    Last Post: 05-03-2012, 11:48 AM
  3. Vintage toilet with no tank question
    By Palladio in forum Toilet Forum discussions
    Last Post: 05-24-2008, 07:10 AM
  4. Vintage Toilet Repair in Historic Home
    By zksmith1 in forum Toilet Forum discussions
    Last Post: 12-30-2005, 02:03 PM
  5. crane toilet
    By ratdog in forum Toilet Forum discussions
    Last Post: 08-25-2005, 08:49 PM
