My setup:
Ulilitech Pro UT202 3/4HP 2-wire pump (12GPM @ 60', 10.8GPM @100').
Well-x-trolWX-202 pressure tank.
Pressure switch set at 30/50 (I think - pressure guage rusted & not reliable).
Water level in well somewhere between 50-70' below ground. I replaced my old pump with the one above, in October, but wasn't thinking about water level at the time, so only have a reasonable guess).
My main issues/concerns are that I am getting what i think is excessive cycling, and also that the tank is 30 years old. i hear water hammer noises. nervous that it's going to go south soon, so this is a pre-emptive fix.
i really don't have an issue with pressure variation. does it exist? yes. but it is not botersome.
but, i ran across the pside-kick product, and it seemed to be a simple solution, and a space saver.
would the product be a good solution for me? the plumbing in the house is modest: 1 bath, 1 washing machine (HE), 1 kitchen sink, 1 dishwasher, and several outside taps (some of which i have soaker hoses/timers attached to, for a small garden, in the spring/summer).
can my pump, using a pside-kick, really handle having a shower, dishwasher,and washing machine all running at the same time? and would i really have less cycling than just replacing the pressure tank with a like-sized model, that would, i assume, not cycle as often?
note: i think my tank is ok, but the pressure switch/tube might be clogged. and my take on it is to not mess with it, since it's technically working, but rather replace it all, since it's all so old.
so, thoughts on a standard tank, or pside-kick, for my situation?
thanks,
sgl
thanks,
sgl
