Results 1 to 9 of 9
Thread: Understanding a Steam Shower Sealed Slip Joint: Photo's, Sketches and Video Tutorial
    Jul 2009
    North Vancouver, BC
    Default Understanding a Steam Shower Sealed Slip Joint: Photo's, Sketches and Video Tutorial
    Post(s) deleted by John Whipple
    Jul 2009
    North Vancouver, BC
    Default First things first - Blocking requirements for framing needs of a sealed slip joint
    Jul 2009
    North Vancouver, BC
    Default Kerdi DS Sealed slip detail - Steam Shower Photo's of Construction
    Jul 2009
    North Vancouver, BC
    Default The long runs are fine John - What about the corners?
    Jul 2009
    North Vancouver, BC
    Default Inside Corner Detail - Sealed Slip Joint Kerdi DS Steam Shower
    Jul 2009
    North Vancouver, BC
    Default Preparing your Durock Shower Walls for a Sealed Slip Joint
    Jul 2009
    North Vancouver, BC
    Default Sealing the corners up tight
    DIY Junior Member s blyth's Avatar
    Nov 2013
    london
    Default Sealed Slip Joint question
    John, how much of a gap should you leave with this method between the ceiling and wall??
    Obviously installing the ceiling board is the first thing done. Is there also a gap when you install the ceiling board, leaving it away from where the wall is? or just when you install the wall board up to the ceiling board? or is there a gap for both the ceiling board install AND the Wall board? Hope I explained that properly. Thx John
    Quote Originally Posted by johnfrwhipple View Post
    Photo: Steam Shower - Source
    Building Steam Showers is much tricker than most people think and much more detailed than most installers have ever imagined. One of the most asked questions of me by my online clients on the subject of steam shower construction (other than what the best membrane) is "How the Hell do you build a sealed slip joint?". This is a good question and one that is very hard to explain. When discussing this detail so much confusion over the detail starts to arise. Look at the steam shower above I build a year back. Look at the volume of steam and steam rises. The most heat and steam concentrated at the ceiling.
    So how do you make a sealed slip joint? I'm working on a simple approach on my current steam shower project here in Vancouver and thought I would share a few of the photo's and the process here in the hopes of helping out more people.
    So first. Lets look at a few photos of a Sealed Slip Joint.
    Photo: Sealed Slip Joint Detail - Source - Page
    Photo: Slip Joint - Source - Page
    Now finding out how to make this sealed slip joint will drive you crazy. I love John Bridge's explanation here on this page. He says "I think it's a normal joint where one plane of tile goes behind the other. More TCA jibberish. Sometimes those guys sit around the table and create new words and terms." - now that makes it all clearer doesn't it... lol
    I have asked many men about this detail. Even the men at Noble Company who's cross section is my standard and never once has the detail been explained properly to me. The closest I have gotten is the detail is designed to allow a little movement. The fold (not really shown in the two images above) creates slack I think and this helps with the overall design and function of the steam shower. BUT - how the hell do the corners work out.
    Lets look at Noble Company's Steam Shower Specification. This is the best diagram online and here it is.
    Photo: Noble Company's Steam Shower Specification - Source - Page
    Notice the Sealed Slip Joint. Notice the roll in the corner. Notice that the backer boards do not meet nor are they sealed together. All details that make you wonder how to achieve this with out screwing up your shower and making this wall to ceiling point a weak link in your vapour armour.
    So - I hope everyone has not falling to sleep because my little detail below is my version of a sealed slip joint.
    Jul 2009
    North Vancouver, BC
  1. Slip joint on shower drain keeps leaking! Help!
    By mattg83 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-15-2011, 06:39 AM
  2. Slip Joint vs Threaded.....J Trap
    By chefwong in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-29-2010, 09:37 AM
  3. Slip joint connections
    By fmc56 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-07-2008, 08:42 AM
  4. slip joint reliability and ferncos
    By adrianmariano in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-28-2007, 06:15 AM
  5. Crooked slip joint.....
    By steveg91 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-14-2006, 10:21 AM
