Thread: Oval shaped lead closet bend???
    DIY Junior Member The Razz's Avatar
    Dec 2013
    Default Oval shaped lead closet bend???
    The 1950s house that I recently purchased has a wobbly toilet.
    Expecting a broken flange, I pulled the toilet to find no flange at all! The toilet is simply bolted to the floor with lead anchors and lag screws. The wax ring is “sealing” the toilet’s outlet to a lead closet bend.
    Unfortunately, the bend is so tight and oval shaped, it prevents the installation of a suitable expandable sealing flange. So, I plan to revamp the piping with ABS and Ferncos.
    Since the piping is in a crawl space and the existing CI is suspended 10-12” below the floor joists I’m wondering… instead of a closet bend off the flange, can’t I simply drop straight down and use a long sweep el to connect to the CI?
    So, flange…8” or so length of ABS…sweep el…more ABS…Fernco to CI?
    Nov 2010
    Maine
    You can. .
    Fernco is a brand name...what you need is probably made by them, but since the pipe is not underground, make sure to use the proper banded coupling - not the thick rubber fitting with only the hose clamps at the end.
    I normally just pull the lead out of the cast iron tee, and use a 4x3 flush bush into a insert rubber pipe donut.
    You can't really clamp onto lead.
    I remove the lead bends, and replace with plastic.
  1. Lead closet bend doesn't reach floor
    By Franklin1918 in forum Toilet Forum discussions
    Last Post: 09-27-2013, 02:19 PM
  2. Removing lead closet bend?
    By lza206 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-06-2013, 07:09 AM
  3. Problem - Closet Flange to Lead Bend
    By madhavok in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-21-2012, 07:48 PM
  4. lead closet bend
    By Robert C1 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-22-2010, 11:52 AM
  5. Replacing a Lead Closet Bend
    By bet3zzz in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-06-2010, 02:07 PM
