Results 1 to 5 of 5
Thread: Reverse osmosis faucet air gap over flows water on the counter
    DIY Junior Member Talisker's Avatar
    Feb 2013
    Texas
    Angry Reverse osmosis faucet air gap over flows water on the counter
    Whenever I turn on garbage disposal, my reverse osmosis overflows water on to the counter and then slowing leaks inside the kitchen sink cabinet. Why does this happen? Please help.
    Jan 2012
    California
    The airgap drain should be located in a different location. i assume you have a saddle tap type of connection. These are technically not to code, but they are common and pose no real world problems. The air gap drain tap should be located on the other sink drain, and it must be installed on the sink side of the p-trap. Look under the sink to determine the best location for the saddle tap.
    You could also update your drain to code with one of the items pictured here.
Size:  17.4 KBName:  drain_boa_02.jpg
    Nov 2010
    Maine
    It overflows because when the disposal is running it won't accept water from the RO filter. Like Dittohead said, Move its drain.
    Feb 2013
    Texas
    Thank you. Plumber had connected reverse osmosis drain pipe in wrong location.
    Central Florida
    That's why it pays to hire a pro.
  1. Reverse Osmosis to Instant Hot Water?
    By evilFive in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-23-2011, 01:53 PM
  2. Reverse Osmosis Filter Stops Making Water
    By Shinshi in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-10-2010, 07:20 AM
  3. Reverse osmosis Water Filter
    By Terry in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-22-2009, 05:55 PM
  4. Reverse osmosis Water Filter
    By Terry in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-22-2009, 11:13 AM
  5. Reverse Osmosis filter and water pressure
    By Kai in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-25-2005, 04:45 PM
