Thread: No grout gap
    DIY Member SH140's Avatar
    Jan 2013
    Vallejo, Ca.
    Default No grout gap
    After thinset dried on 2x2 porcelain floor tile, I noticed 3 tiles had little to no gap for grout. Does anyone know of any inexpensive tools (this will probably be a one time use for this tool) that will work for widening the gap. Something I can use with my drill would be best as the gaps in question are perpendicular abutting the shower curb.
    Appreciate any advice
    Jul 2009
    North Vancouver, BC
    Default Grout removal Tool
    The best tool for delicate work is a straight razor blade. Make sure you understand that the box cutter is the most dangerous tool on any job site before tackling the job yourself.
    A box cutter like this will make short work of fresh thin-set.
    Photo: Box Cutter - Image Source - Page
    Getting the sides of tile clean is important before a grouting job. Ideally the sides are all clean and free of thin-set. Ideally you have at least the depth of room for grout as you do the width of the grout joint.
    For a 3/8" tile set with a 1/8" grout joint I would like to see personally a good 1/4" of depth.
    Jul 2009
    North Vancouver, BC
    Default Cleaning the grout joints with a box cutter and rag
    I took these pictures a week or so back. I'm preparing the grout joints 1/8" wide and 3/8" deep for an Epoxy Grout from Laticrete called Spectra Lock Pro. To make sure the grouts are free from thin-set, dust and drywall compound I double checked them all.
    I find it takes almost twice as long to prepare for grouting as it does take to grout.
    Once free of material I use a wet rag wrapped around the blade so I can get pressure sideways.
    You don't want lots of water. The grout joint needs to be clean but not wet before grouting.
    It's best to make sure you skip grouting that day if you saturate the grout joints with water.
    Here are the pictures. Hope this helps. Remeber that the box cutter is a dangerous tool. Press to hard and little segments of this type of blade go flying. Press to deep and you can cut heating wires or waterproofing membranes!!!
    Careful.
    Ready for grout.
    Jul 2009
    North Vancouver, BC
    Sorry I showed here cleaning a grout joint not cutting a tile to make it bigger.
    HArd to tell if it is possible. I use a little diamond grinder bit on my Fein Tool.
    This is one of the most versitile tools. In a tight space I think I would just pop out the old tile if possible and re set....
  1. Grout
    By John28 in forum Shower & bathtub Forum & Blog
    Last Post: 03-19-2013, 12:45 AM
  2. Grout Problem
    By richrc1131 in forum Remodel Forum & Blog
    Last Post: 02-24-2010, 03:09 AM
  3. Grout Questions
    By jdbs3 in forum Shower & bathtub Forum & Blog
    Last Post: 10-15-2009, 04:01 PM
  4. HELP- Sealing Grout
    By cma in forum Remodel Forum & Blog
    Last Post: 06-17-2009, 04:25 PM
  5. Grout
    By skipsleather in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-04-2008, 01:53 PM
