Results 1 to 3 of 3
Thread: Genie IntelliG 1200 won't close unless holding wall panel button
    DIY Junior Member mortal798's Avatar
    May 2011
    Pinckney, MI
    Default Genie IntelliG 1200 won't close unless holding wall panel button
    As the title states, I have a relatively new Genie IntelliG 1200. It has been fine for the last year (it's only one year old). Now one of the sensors flashes red 4 times, pause, flashes red 4 times, pause, repeat... I can't find anything anywhere that tells you what the 4 flashes mean. I found lots of stuff for flashing of the power head LEDs, but not for the sensors. It just says 'call a technician'.
    I know that the wiring is good. I did a continuity check and voltage drop test of the circuits ( I am an ASE Certified Master Auto Technician) and got .1 ohms of resistance and .013v drop. The wires are good.
    Can anyone tell me what the flashing of the sensor led means?
    DIY Member ankhseeker's Avatar
    Oct 2013
    California
    Here is a link to the manual that states it the source isn't sending or defective.
    http://www.geniecompany.com/data/pro...ft-install.pdf (pg 26)
    Mar 2011
    Houston, TX
    It is most likely a sensor adjustment causing the error and the door does not know that it is completely open.
    UN-Plugging the controller would be the first thing to try.
    If that don't work then check the Door End Stop Settings.
    Good Luck.
  1. shower drain too close to the wall
    By Talisker in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-04-2013, 06:56 AM
  2. Replies: 4
    Last Post: 08-02-2012, 10:08 PM
  3. Help! drain too close to wall for toilet to fit
    By chelsea in forum Toilet Forum discussions
    Last Post: 03-06-2008, 11:29 AM
  4. Toilet too close to the wall
    By zcchryst in forum Toilet Forum discussions
    Last Post: 09-19-2006, 01:59 PM
  5. Flange Too Close To the Wall
    By Verdeboy in forum Toilet Forum discussions
    Last Post: 07-12-2006, 10:31 AM
