Results 1 to 10 of 10
Thread: Dryer Static - modify dryer grounds....amicrazyorwhat?
    DIY Junior Member jgold47's Avatar
    Nov 2010
    Detroit, MI
    Default Dryer Static - modify dryer grounds....amicrazyorwhat?
    Now that the wife wont let me use dryer sheets or anything similar on the new baby clothes, the static is driving me nuts. I've tried all of the prescribed methods - vinnegar, dryer balls, aluminum foil (more on that) with no success....came across a length of stranded copper grounding wire from an old project. What about modifying the dryer to have a greater grounding potential? I'm not talking about the motor which would still be connected to house ground,, but introducing some sort of chassis ground with a super low potential directly to earth (in this case to a blackpipe running overhead, which is not tied to house ground...
    I havent dug into the wiring diagram for the dryer yet, although I suspect there is a ground connection from the drum to the normal chassis ground. I want to isolate that into its own ground. Any thoughts?
    DIY Senior Member bluebinky's Avatar
    Aug 2011
    Santa Clara, CA
    I doubt grounding the drum will help. It's the fabrics rubbing together that causes the static.
    I put only clothes in the dryer and don't get *any* static anymore. The things that helped were:
    - avoiding synthetic fabrics (and wool).
    - using less detergent.
    - throwing in a big worn out cotton towel with every load.
    Jun 2007
    North Carolina
    The tub turns around and around so to try to attach a wire to it would only cause the wire to wrap around the tub until it pulls free.
    Mar 2011
    Houston, TX
    The Drum is already grounded thru the Drum Bearing.
    Some dryers do have humidity sensors in the drum, and you can put the dryer on less dry.
    The dryer you dry the cloths the more static charging. Just do not dry them so long, save power.
    All You can do at this point is say Yes Dear.
    Enjoy the Baby.
    There are some hypo-allergenic perfume free fabric softeners out there. I use All, unscented....normal ones just make me itch all over.
    Aug 2011
    Santa Clara, CA
    Yes, enjoy the Baby. If static cling is all that's bothering you, then you're doing all right.
    Nov 2010
    Detroit, MI
    thanks everyone. I stumbled upon the wiring diagram for the dryer, and correct, it grounds through the drum, and actually back through the white wire to the panel. Adding or changing that around would likely have more issues down the line. I've tried using vinnegar in the wash and it seems to help. I guess I'll stick with that for now. I've also gotten these (allegedly) metal impregnated cloths that seem to be helping as well.
    Mar 2011
    Houston, TX
    Great if it works for you.
    Vinegar is used to set color in fabrics. I would not mix any New color fabrics.
    Acid can be hard on the Mechanics also.
    Enjoy.
    Nov 2010
    Detroit, MI
    Enjoy.
    youre using an extremely dilute amount of 5% vinegar. I'm guessing areas of the country have more acidic water than what this dilutes to.
    assumedly, everything I'm washing is color safe.
    I'm allergic to dryer sheets. Haven't used them in years. I don't even notice the static electricity anymore.
  1. Replies: 2
    Last Post: 11-28-2013, 06:14 AM
  2. Broken dryer on washer dryer combo
    By Kristoffer in forum Electrical Forum discussion & Blog
    Last Post: 12-14-2011, 11:37 AM
  3. Question? Will a Energy efficient dryer cost more or less then a Gas dryer
    By 87vertgt in forum Electrical Forum discussion & Blog
    Last Post: 09-15-2011, 05:37 PM
  4. Dryer is out
    By Cookie in forum Health and Wellness Forum
    Last Post: 04-14-2011, 09:13 AM
  5. Gas Dryer
    By Southpaw134 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-09-2009, 06:47 AM
