Results 1 to 6 of 6
Thread: Can anyone identify a way to remove these handles?
    DIY Junior Member dangros's Avatar
    Nov 2013
    reston, va
    Default Can anyone identify a way to remove these handles?
    We just purchased a house which has a leaky faucet. I tried to turn it off but the handle just continues to turn w/o stopping and it made the faucet leak worse. I had to turn it off at the main. I took an image of the handles.
    To make matters worse, when I lift up on the handle, I can feel it pull and stretch on the pipes below the tile. Any idea how I can remove these and safely install a new set?
    DIY Senior Member kcodyjr's Avatar
    Nov 2013
    Chelmsford, MA
    That looks like a set screw on the back of the faucet. There should be on on each of the handles somewhere, too.
    On the handles, it might be under a cap at the very top, if it isn't visible elsewhere.
    Nov 2013
    reston, va
    no set screw that I can find. There is a top that pops off but I just see a threaded hole and what appears to be the end of a screw in it. The handle ends screw off but when you look in there you see the attached. I've also popped off the top cap and included that image as well.
    But I dont see a way to pull this thing out. I dont want to pull too hard b/c I can tell it's attached to the pipes and any force, yanks on the pipes due to the terrible install from the previous owner who must of taken every shortcut in the book
    Nov 2013
    Chelmsford, MA
    That upper image is looking down the handle end? Does that little whackadoodle turn?
    Nov 2013
    reston, va
    the first of the 2 images is from the side view of the handle. I screwed the end off and am looking directly into it. The bottom or 2nd image is from above. It also has a cap that I poped off.
    It looks a lot like this handle but slightly different
    http://www.moen.com/brantford/brushe...UMER%3AT6620BN
    I tried to put a screw driver in there and it did NOT turn.
    The chrome "dome" thing under the handle may unscrew and remove the handle with it.
  1. Help me identify and remove this Delta shower faucet
    By Drfranks in forum Shower & bathtub Forum & Blog
    Last Post: 09-30-2013, 10:31 AM
  2. Cannot remove bathtub handles
    By quickstep in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-21-2013, 07:47 AM
  3. Sayco shower leaking - cannot remove handles
    By orion6192 in forum Shower & bathtub Forum & Blog
    Last Post: 07-11-2011, 12:36 PM
  4. Unable to remove control handles/lever
    By maree in forum Shower & bathtub Forum & Blog
    Last Post: 06-27-2008, 05:20 PM
  5. How to remove bathtub faucet handles?
    By miranda12 in forum Shower & bathtub Forum & Blog
    Last Post: 12-18-2006, 04:53 PM
