Results 1 to 5 of 5
Thread: Volume of flush
    DIY Junior Member tmurphy's Avatar
    Jul 2009
    mpls,MN
    Default Volume of flush
    How can I increase the volume of water moving from the tank to the bowl. Put in a Fluidmaster retro kit for a client, they are not happy with how it flushes(American Standard)
    The only ways are to either raise the level of the water, or use a different tank flapper..
    Sep 2013
    If that was Fluidmaster Pro550K Dual Flush, see
    http://www.youtube.com/watch?v=cRRWVZZTOSo toward the end.
    The flapper has a rotating adjustment for volumn.
    It's meant to be all purpose, meaning it can dial down to 1.6 gallons, or be dialed up for more.
    http://www.fluidmaster.com/our-produ...epair-kit.html
    The Adjustable flapper
    is set on #9 from the
    factory. To adjust,
    rotate rubber flapper
    left or right to position
    # in front of chain to
    get desired flush.
    The higher the number
    setting the longer the
    flush. The lower the
    number setting, the
    less water used.
    Jul 2009
    mpls,MN
    Thanks to all
  1. Low volume on hot water
    By Footman_75 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-23-2012, 08:35 AM
  2. Pipe Volume
    By tel in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-23-2009, 06:05 AM
  3. Low Pressure/low volume
    By secrest2032 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-18-2008, 08:41 AM
  4. Low Volume Flush
    By plunging_queen in forum Toilet Forum discussions
    Last Post: 04-04-2006, 01:07 PM
  5. low pressure/volume
    By kwangtzu in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-25-2005, 09:42 PM
