Thread: Air fitting for blowing out system
    DIY Junior Member kaw550's Avatar
    Oct 2013
    MA
    Default Air fitting for blowing out system
    Does anyone make a compressor fitting or schrader (sp?) valve that I can tie into my plumbing? I did ask a local supply shop but they didnt have anything.
    Right now I am planning to tie into the pex plumbing with a T, add a valve and a compressor fitting with a hose barb that I can clamp on.
    Sep 2013
    Amflo 701-2 has a 1/4 inch pipe thread and a Schrader valve on the other. However for a temporary tool. Quick-connect fittings with 1/4 pipe thread are very common.
    Feb 2011
    NW Ontario, Canada
    Google snifter valve.
    DIY Senior Member guy48065's Avatar
    Sep 2013
    SE and north MI
    The Big Box stores carry M & F hose thread ends. Screw an air hose quick disconnect into a female garden hose connector and you have a great tool for blowing out lines. I use a cheap oil-less compressor set to 40psi hooked to an outside hose bib to pressurize the system. Neither of the cottages I've owned have been plumbed with sloping pipes that would drain naturally. Using air makes winterizing a 10 minute job.
    Romeo and Atlanta, MI
  1. What kind of union fitting is this? Ford Fitting
    By DavidTu in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-21-2011, 10:25 PM
  2. Timer System Blowing Fuses
    By gwysocki in forum Irrigation / Sprinkler Forum
    Last Post: 07-12-2009, 08:41 AM
  3. Blowing well
    By hickster in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-26-2008, 05:35 AM
  4. blowing out a well
    By toolmantim in forum Pumps and Tanks Well Forum & Blog
    Last Post: 04-03-2008, 07:43 AM
  5. air blowing OUT of well
    By Raucina in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-31-2007, 09:30 AM
