Thread: Runaway Thermostat?
    DIY Senior Member Briandl's Avatar
    Feb 2008
    Texas
    Default Runaway Thermostat?
    Relief valve opened on my hot water heater. The water was very hot from the tap, so I turned the unit off and ran enough water through it to get cold water into it. I checked the valve to make sure it was working properly, and then tried to turn the unit back on, however it would not turn on. I reset the breaker on the thermostat and it came back on.
    So it seems to me I have a runaway thermostat.
    This is just a point of use Ariston 4 gallon water heater, just want to be sure before I go pick up a thermostat, because I suppose it could also be the element.
    (Also it's just a small point of use unit so it's off until I get it fixed)
    DIY Junior Member Raspy's Avatar
    Dec 2013
    Northern Nevada
    The element only responds to the thermostat and cannot make the water heater "run away"
    DIY Junior Member WyrTwister's Avatar
    Feb 2014
    Texas
    The tstat only switched one of the two hots ( 240 VAC ) I saw a WH that had an element shorted to ground on the un-switched hot . Therefore , part os the element was apparently running / heating 24/7 ?
    The big box stores carry a plumbers pack with upper and lower tstat and 2 elements . That might be the way to go ?
    However , if yours is a 4 gallon unit , is it 120 VAC ?
    God bless
    Wyr
    Mar 2011
    Houston, TX
    I agree that a shorted element can cause the problem.
    If they short they can weld the contacts on the thermostat.
    Is that unit on 120V or 240V ?
    Good Luck.
  1. Runaway stacking problem with water heater
    By Melissa2007B in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-16-2012, 06:44 PM
  2. Thermostat
    By Giles in forum HVAC Heating & Cooling
    Last Post: 12-15-2010, 11:19 AM
  3. Is it my thermostat?
    By cpio in forum HVAC Heating & Cooling
    Last Post: 11-06-2009, 05:09 PM
  4. Can I use one thermostat?
    By fazy in forum HVAC Heating & Cooling
    Last Post: 11-09-2008, 07:27 PM
  5. I need a better thermostat
    By got_nailed in forum HVAC Heating & Cooling
    Last Post: 05-31-2007, 09:54 AM
