Results 1 to 6 of 6
Thread: Please review this shower pan install. Did I pay a lot of $$ for subpar work?
    DIY Junior Member cubgirl's Avatar
    Nov 2013
    Alabama
    Default Please review this shower pan install. Did I pay a lot of $$ for subpar work?
    Hi and thank you for this forum and allowing me to seek help.
    I've been arguing with my plumbers for 2 days. So I'm sending pictures of the 32x60" shower pan install for an outside opinion.
    The plumbers said they had to use shims to level the pan because the subfloor was so out of level. They used some trim pieces I have from a previous job. I questioned the job but they insisted they knew what they are doing. I called owner of company and he sent the two plumbers back out and they told me they put thinset in the middle of the pan and the trim was used because the subfloor was so out of level. They said if I wanted them to reinstall the shower pan, I'd need my carpenter to level the subfloor first. After they left, I crawled around on the floor to check their work closer.
    It appears the plumbers have put 5/8" trim pieces all around the shower pan -- under both the drain end and the far end (see pics). I am not sure why they did this. I checked level of the subfloor in the 32" direction and the 60" direction and both appear to be near level (see pics). The subfloor is no where near as off-level as indicated by the plumber's use of 5/8" trim pieces being used as shims.
    In addition, I checked the pan itself. It appears to have a "hump" in the middle of it (see photos). Is this normal? It may be the way the pan is manufactured or the thinset in the middle of the pan may be the cause for the hump or the drain may be too high -- I am not sure.
    Please look at the pictures of this shower pan install and give me your opinion. I paid professional plumbers a lot of $$ installing this.
    Thank you,
    Cubgirl
    P.S. Not all the pictures uploaded (threre are 9). I will add 2nd thread with the 4 missing pictures. Thanks again.
Size:  31.8 KBName:  photo-2.JPG
Size:  32.3 KBName:  photo-3.JPG
Size:  27.6 KBName:  photo-4.JPG
Size:  33.8 KBName:  photo-5.JPG
    Jul 2009
    North Vancouver, BC
    Can you see underneath?
    Does the pan feel solid under foot?
    Without reading the installation instructions, it's hard to say. But, I will comment that most pans call for them to be installed on a level floor, with 100% contact. If yours does, then no, it is not installed properly. It must be solid with no flex, or it will eventually crack and leak.
    Jan 2008
    I can't help but to think that perhaps the pan is sitting in a mortar bed, but there is no way to tell looking at those pictures. If it feels solid with no flex in the pan, it will probably be fine.
    Nov 2013
    Alabama
    We pulled it up and there was still wet compound in the middle underneath (two weeks after install) just in spots. Not sure what it was but it wasn't sandy mortar - more like joint compound. This also meant that the trim pieces on the sides were weight bearing. This is a no-no.
    My OTHER plumber (who I've used before but he was on vacation during this install) is going to reinstall the shower pan with mortar to level it on the floor. It needs to be in full contact with floor, not raised up with make-shift shims like the old guys did it.
    BTW: I squawked so much, I got my money back without even asking for it.
    Thanks...
    Jan 2008
    Good for you! Better to fix people's mistakes before the work progresses further and becomes a more expensive problem down the road.
  1. Review Shower DWV Diagram Please - ready to install
    By rafigso in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-26-2012, 04:09 PM
  2. Fleck 5800SXT first install review
    By ditttohead in forum Water Softener Forum, problems, installation and reviews
    Last Post: 04-04-2012, 10:55 AM
  3. hvac and duct work DIY install
    By rocinante in forum HVAC Heating & Cooling
    Last Post: 07-09-2011, 02:55 PM
  4. How do I install an old work box?
    By michdaley in forum Electrical Forum discussion & Blog
    Last Post: 06-29-2010, 09:11 AM
  5. wanting to do install work
    By motlot77 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-24-2005, 09:18 AM
