Results 1 to 6 of 6
Thread: filter for mild sediment, occasional sulfur smell
    DIY Senior Member lifespeed's Avatar
    Apr 2007
    California
    Default filter for mild sediment, occasional sulfur smell
    My mother has minor water quality problems from her well: a small amount of sediment, occasional minor sulfur smell in the cold water, and about 5 GPG hardness. No iron detected when she had it tested, but she does get slight iron staining on occasion. Probably not a justification for an iron filter, especially if a softener gets installed.
    First I would like to address the sediment and occasional sulfur smell. I am thinking this would be done for both inside and hose bib water and located in the well shed. A one-tank solution would be ideal. Is this realistic - would a single catalytic carbon tank do the trick? I know carbon is not the ideal, most powerful media for sediment OR sulfur, but does an OK job on either especially if the problem is not that great. Also would like to consider the use of a softener/greensand valve to allow occasional disinfection of the carbon by drawing in chlorine during the "brine" cycle. She currently has several BB filters in parallel that sometimes grow algae and get restricted over time.
    Given the modest scale of the problem I am hoping to forgo a dedicated sediment filter tank, chlorine injection, contact tank and THEN carbon tank.
    Thoughts?
    Lifespeed
    DIY Senior Member Reach4's Avatar
    Sep 2013
    Catalytic carbon with backwash would do well. I would also shock chlorinate the well and the filters and the plumbing system. I would get chlorine test paper/strips and test for 200 ppm chlorine from the well, and chlorine from each tap you have. I wound make sure the hot water taps get at least 100 ppm. Let that all sit for a while. http://deq.mt.gov/wqinfo/swp/PDFs/we...sinfection.pdf is one of many descriptions.
    I expect your BB filters are in series.
    Apr 2007
    California
    Her husband put them in parallel (not series) as an attempt to maintain flow as they clogged. It is quite the Rube Goldberg arrangement, hence my attempt to try and get something in there that is more effective and low maintenance. He is an older guy who experienced the headaches of softener ownership 30 years ago and is since then opposed as they are "too much trouble and maintenance". Trying to show him the light that a newer, reliable, correctly-configured backwashing filter and softener would fix their problems. My mom really wants the hard water deposit, clogging and occasional smell problems gone. But the medium-grade nature of the problems enables the argument they "don't warrant fixing"
    I have personally seen algae grow in the filter housings. My mom says they eventually get plugged and the water starts to smell bad. It does not appear an ideal solution.
    Lifespeed
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    Sounds feasible. I was thinking, what if you used a dip feeder in the same fashion as a resup feeder. It would drop a chlorine solution into the brine tank.. This would sanitize it with each Regen. Food for thought.
    Have they had a Coliform bacteria test done? Due to the algae growth, I suspect clear housings out in the sun. They and other equipment should be shaded and protected from rain.
    Apr 2007
    California
    The utility shed provides shade, but I guess is not totally opaque. Yes, clear housings and no coliform.
    Lifespeed
  1. Help Deciding Best Way to Get Rid of Sulfur Smell. Iron filter or Chlorine? Other?
    By carfan87 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 03-17-2011, 06:12 AM
  2. Use Chlorine (Charcoal) filter in Whole House Sediment Filter Housing ??
    By kstuart in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-03-2011, 02:04 PM
  3. Research on Sulfur Smell
    By Huskymaniac in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-06-2006, 07:11 PM
  4. Sulfur/rotten egg smell
    By Guest in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-05-2006, 06:24 PM
  5. Sulfur Smell again
    By PennyNJ in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-01-2005, 11:59 AM
