Thread: Navian heater clean procedure
    DIY Junior Member grande's Avatar
    Nov 2013
    South Carolina
    Default Navian heater clean procedure
    I have a Navian NPE 240 tankless water heater. It has a small .5 gallon tank and a recirculation pump. Its time to flush the system for the first time. Is there an override in the system so I can use the recirculation pump in the unit to do the flush?
    Feb 2005
    you would have to post a picture of your unit...
    usually there are a couple of bypass valves installed
    under the unit for easy flushing......
    this is normally done by a certified technician with the proper pump
    and fluids to flush through the unit...
    were these installed ???..
    Nov 2013
    South Carolina
    It does have flush valves, I installed when I installed the unit. My question is there a way to use the internal recirc. pump to do the flush and not have to have an external pump. ie only run the internal pump in the heater?? I was thinking there might be a pump test or flush mode built into the logic on the controller.
  1. Navian flow sensors.
    By tntent805 in forum Tankless Water Heater Forum
    Last Post: 04-24-2013, 08:07 PM
  2. Procedure to bullnose porcelain tile
    By SH140 in forum Shower & bathtub Forum & Blog
    Last Post: 04-09-2013, 07:40 PM
  3. Navian ch-210 heating side will not flow
    By CHAS7777 in forum HVAC Heating & Cooling
    Last Post: 10-29-2011, 08:39 PM
  4. Bladder setup procedure
    By Gpace1 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-27-2007, 11:51 AM
  5. Procedure to set pressure
    By ddavid1 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-15-2005, 11:29 AM
