Results 1 to 9 of 9
Thread: 3 inch Double Fixture Fitting with 2 inch reducers?
    DIY Junior Member Steve1911's Avatar
    Nov 2013
    Georgia
    Default 3 inch Double Fixture Fitting with 2 inch reducers?
    I am fixing a poorly done single to double vanity conversion. I have a 3 inch stack (3 inch drain and 3 inch vent pipe, inline) in the wall that I will be attaching the vertical hubs of a Double Fixture Fitting, but I need 2 inch hubs on the horizontals to stub out the sink drains with 2 inch (or 1 1/2 inch?) abs. The smaller diameter pipe is also necessary to go through my wall studs.
    Is there any reason I should not cement 2 inch reducers to the 3 inch horizontal hubs of the Double Fixture Fitting?
    Crude diagram of my elusive Double Fixture Fitting. Thanks for the help.
    ll
    2= =2
    ll
    Jan 2008
    Have you ever seen a 3" double fixture fitting? If they exist, it is not something we normally see.
    Nov 2013
    Georgia
    Thanks for the reply. This is what I found from grainger 3 inches all around?
    http://www.grainger.com/product/MUEL...UR6?s_pp=false
    If that doesn't work with 2 inch reducers on the horizontals, or the sizing is not actually what I think it is, is there anything wrong with buying a 2 inch Double Fixture Fitting and using reducers (3 inch to 2 inch couplings) to fit my vertical 3 inch vent and 3 inch drain to the 2 inch Double fixture fitting?
    No problem using the reducers.
    Jan 2008
    I have to back-pedal a bit on my comment, as the 3" double fixture fitting is pretty much unheard of in the stores around here. ABS drain piping is pretty much unheard of here also, but that is a whole different topic.
    If you had such a fitting, there would be no reason you could not use reducers on the inlets. You can always go from a small trap arm to a larger drain, but never the other way around.
    Nov 2013
    Georgia
    Thank you both.
    Nov 2013
    Georgia
    Thanks for the information so far. This is my plan and I just would like you guys to check it out and critique if necessary. Specifically, will the 3"-1.5" flush bushings be acceptable and are the trap arm lengths OK. I like the 1.5" trap arms as opposed to the 2" in my original post due to the wall studs being 2x4's. I will also re route the supply lines to come out of the wall instead of the floor.
    I used to install a lot of them. With the new 3" flush valve toilets, I prefer to plumb them seperately now.
    It should be fine for the lavs there.
    Nov 2013
    Georgia
    Excellent. My worry was the 1.5 inch flush bushings in the inlets of the double fixture fitting would mess with the water flow but it seems I'm good to go.
    Time to order the parts and get to work. My goal is to make it look as good as some of the pictures I've seen here. You guys are a great help. Thanks
  1. 10 inch toilet in 12 inch rough in - tank brace suggestions?
    By zsuguru in forum Toilet Forum discussions
    Last Post: 02-02-2013, 07:58 PM
  2. Converting to double sink-drain pipe too close to stud for double fixture fitting.
    By Finch85 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-11-2012, 06:04 PM
  3. we have a 16 inch rough-in andcannot find a tolet ith a 16 inch roughin anywhere
    By nancyann in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-17-2011, 04:22 PM
  4. Cable tool or bore drill? 5 inch pvc or 4 inch steel?
    By Barnes in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-16-2008, 05:48 AM
  5. Double fixture fitting for toilets
    By Hazel in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-07-2006, 05:44 PM
