I'm replacing a 15 year old pump in a hot water recirculation system. The current system does not have a check valve between the pump and water heater (The pump discharges into a tee at the water heater drain connection).
I'm looking for 1/2" brass, preferably sweat. Can someone recommend a part number and manufacturer? Should I use a swing check or spring style?
I found a Milwaukee Valve 1548T12 (sweat) or 548T12 (threaded) spring style, but not sure if this is a good selection.
Thanks,
Thanks,
