Results 1 to 6 of 6
Thread: jet pump troubleshooting
    DIY Junior Member hemster87's Avatar
    Nov 2013
    nc
    Default jet pump troubleshooting
    I installed a two line jet pump for a water holding tank...when I turn it on the pump kicks on for two sec then kicks off..it does that about every min...it want build pressure and keep pressure on the water line... what could be the problem?
    DIY Senior Member craigpump's Avatar
    Apr 2012
    ct
    Without more info, it sounds like its pumping against a closed valve.
    Mar 2011
    Houston, TX
    Quote Originally Posted by hemster87 View Post
    You should verify the correct Motor Voltage.
    Good Luck.
    Sep 2013
    Could his pump need priming?
    Feb 2011
    NW Ontario, Canada
    Are you pumping into or out of the holding tank? Is the holding tank a pressure tank or non-pressurized?
    Jan 2008
    Virginia Beach, VA
    With the limited information I'd say your holding tank is full of water. You need a bladder type tank or a Pside-kick.
    Porky Cutter, MGWC
    (Master Ground Water Consultant)
  1. Troubleshooting steps a Gould 1/2 HP pump
    By eod4647 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-24-2012, 12:41 PM
  2. Troubleshooting Well Pump Electric
    By CHOLLA BOB in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-07-2012, 11:58 AM
  3. PRV troubleshooting...
    By Runs with bison in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-03-2009, 01:16 PM
  4. Troubleshooting
    By davewest in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-24-2009, 11:51 AM
  5. Well x Trol -wx 302 Troubleshooting??
    By Barodian in forum Pumps and Tanks Well Forum & Blog
    Last Post: 10-09-2007, 05:38 AM
