Results 1 to 7 of 7
Thread: Retrofit existing fixture for motion detecting
    DIY Junior Member Hunter01's Avatar
    Apr 2013
    Wisconsin
    Default Retrofit existing fixture for motion detecting
    Does someone make a retrofit kit for existing outdoor light fixtures? I'm looking to make two of my six outdoor lights (matching design) into motion detecting mode (dusk to dawn). Tried a search on this site and a search for products without much success (Did find one for $65 - could easily buy a new fixture for that, but it wouldn't match the others).
    Yes, I have a couple of older versions of these (and there are others) in service for over 20-years. http://www.acehardware.com/product/i...ductId=4027916
    Apr 2013
    Wisconsin
    Thanks for the quick response. I looked the the site and wondered if the wire between the sensor and box has to be enclosed somehow - conduit or similar?
    Depends, but on many of them, the lead to the actual sensor is low-voltage, and can be exposed. You may be able to read the instructions on the manufacturer's website to see exactly what's required.
    Apr 2013
    Wisconsin
    OK, nothing is ever easy - Did a little checking on the Heath/Zenith unit and the control box requires a 4" electrical box in the wall for mounting (size requirements). Mine, of course, has a shallow round box - no room. Any other specific recommendations? May have to go with new fixtures. Also, the existing fixtures are fully enclosed, bulb upright, not open bottom.
    Depending on how your existing lights are mounted, just buy a cheap motion sensing fixture and mount the sensor on your existing box, even if you have to use an extension, then connect it to the wiring as per the directions. However, if one switch controls all the lights, including the "dark" ones, it will not work, because a dusk to dawn light needs continual power.
    DIY Member ankhseeker's Avatar
    Oct 2013
    California
    I just drilled a hole underneath the light in the lower section of the light fixture and mounted the sensor there. Only 3 wires to deal with. I bought mine at Home Depot for $24 2 years ago.
    You can always tape the switch on so it won't get bumped. It is nice to be able to turn the switch off and on to have the lights be constant on.
  1. Tee into existing stack-retrofit
    By scdean in forum Canadian Plumbing Code Questions
    Last Post: 02-23-2013, 08:05 AM
  2. What box is best for Outside Wall Light Fixture in Existing T-111 to cut in?
    By LFM in forum Electrical Forum discussion & Blog
    Last Post: 06-29-2010, 07:50 AM
  3. Outdoor Motion Detecting Lights switch location
    By Lakee911 in forum Remodel Forum & Blog
    Last Post: 05-12-2008, 03:52 PM
  4. Connecting Motion Activated to Non Motion activated Flood Light
    By zapped in forum Electrical Forum discussion & Blog
    Last Post: 11-30-2007, 07:20 AM
  5. motion sensor shut-off
    By gradog in forum Pumps and Tanks Well Forum & Blog
    Last Post: 11-11-2006, 03:34 PM
