Results 1 to 7 of 7
Thread: Uponor AquaPEX size 1/2 vs 3/4
    DIY Junior Member petepdx's Avatar
    Jun 2006
    Portland, OR USA
    Default Uponor AquaPEX size 1/2 vs 3/4
    Getting ready to change the galvanized with AquaPEX in my urban 1950's rancher with full basement (easy access to everything for a change!!!)
    I'm going to use 1" up to a manifold, but on the other side I can't decide if I should use 1/2 or 3/4 ?
    The coming summer I'll replace the line from the meter with 1" as well.
    The service meter will more then likely stay 3/4" the city wants over a $1,000 to change it from 3/4" to 1", but the option will be there.
    -pete ready to order the red&blue ...
    DIY Member DaveHo's Avatar
    Mar 2010
    SE PA
    Home run system? Unless you have some gigantic tub to fill, 1/2" is plenty big save for maybe outdoor hose bibs. You might even want to consider going with 3/8" for some of the hots if it's a long run. It'll cut down on the wait for hot water.
    Many fixtures in the house are flow restricted. Those that typically aren't include: washing machine, tub filler, hose bibs, laundry sink. A dedicated shower, if you've got more than one head, can use a larger supply line as well. If the run is long, a larger pipe may be called for.
    Jun 2006
    Portland, OR USA
    Screwed up my search of the forum, looks like this question has been asked quite a few times
    Sorry for the repeat ...
    -pete
    Your 1" PEX main line will only be slightly larger than a 3/4" copper or galvanized line, so the 3/4" meter will be adequate.
    The 3/4" meter is fine, I would mate that with a 1" poly or 1-1/4" PEX line. Assuming this is a three bath home.
    Jun 2006
    Portland, OR USA
    Thanks Terry. I've received pretty much the same. The house is 2bath. For the main distribution within the house I'm going to use 1" Uponor/Auqapex. Being a tool nut, I bought the Milwaukee M12, I have another house that will need re-plumbing so the two gave me justification :-), It limits me to 1". For the line to the meter, I'll go with PEX 1-1/4" if I can rent a tool, if not I'll go as you recommend 1" PE.
    Tossing the idea to just use a couple small 3-4 outlet manifolds and using tees for the outside hose bibs. The curse and blessing of so many options
    -pete
    Again thanks,
    -pete
    (*) wish
  1. Using aquapex instead of hePex
    By technogirl74 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-16-2013, 07:52 PM
  2. Uponor Aquapex Tubing and Ultraviolet Light
    By WillieK in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-21-2012, 06:34 AM
  3. Re-plumbing the house with Uponor Aquapex, have a couple of questions
    By DaveHo in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-04-2012, 12:56 PM
  4. Red/Blue AquaPex (Wirsbo/Uponor) Scratch Question.
    By OldPete in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-16-2006, 07:17 AM
  5. cpvc vs aquapex
    By sarasota,fl in forum Remodel Forum & Blog
    Last Post: 09-14-2005, 01:23 PM
